Old 08-29-2014, 07:34 PM   #1
Big Blue
Big Blue's Avatar
What is this? and ?????
This is above the E BRAKE, What is it? and what wire (s) can go on it? The wires that you see are to mine.
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 08-29-2014, 07:40 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: What is this? and ?????
Looks like a ground connector. It would have to be screwed to metal.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-29-2014, 07:50 PM   #3
MountainGoat1966
Sean is correct, it's your main ground connection terminal for many underdash items.
It bolts to the parking brake mechanism in order to work right.
I believe it's a 5/16-18 bolt.
Or the metric equivalent.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 08-30-2014, 09:20 AM   #4
Big Blue
Big Blue's Avatar
Thanks for getting back. That's what I thought it was. Because of the different color wires I got confused.
Thanks, John
Big Blue ( John )
Old 09-07-2014, 12:23 AM   #5
solidaxel
solidaxel's Avatar
Who has them in there catalogs?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-07-2014, 12:51 AM   #6
kalbert
I'm not sure the pink/black wire goes there. Pink/black is usually + key on. Obviously having + connected directly to - is bad!
kalbert is offline   Reply With Quote
Old 09-07-2014, 01:17 AM   #7
gmachinz
Yeah....NO other colors than black belong there. All pink leads are switched 12V accessory leads. And that ground bolts behind the instrument cluster towards the left-kinda directly behind the LH vent on the actual cowl section of the metal dash.
gmachinz is offline   Reply With Quote
Old 09-07-2014, 11:39 AM   #8
Big Blue
Big Blue's Avatar
Thanks For getting back, The wire you see are not what I did. They were on when I got the truck. I have no idea where they went.
Thanks Again,
John
Big Blue ( John )
Old 09-09-2014, 10:34 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
yup should only be black
hard too see it back there
but the closest pink i see might be the buzzer?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
