Old 08-29-2014, 11:01 PM   #1
Nate.n.1989
1992 Scottsdale Cluster Swap Help
As funny as this is going to sound to most truck owners, I'm looking to swap out my needle gauges to the older moonies, funny I know, but I actually prefer the moonies over the needles, does anyone know what it would take to do the swap considering my Scottsdale is a 92? I know they have different connectors, any help is appreciated. Thanks
1992 Chevy Scottsdale 305 5.0L 2WD
Nate.n.1989 is offline   Reply With Quote
Old 08-30-2014, 03:21 PM   #2
Cabnchassis
Re: 1992 Scottsdale Cluster Swap Help
First thing I'd check is if the sending units in your truck supply the same voltage as the ones in the older trucks.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 08-30-2014, 05:57 PM   #3
54 jimmy
54 jimmy's Avatar
shouldn't be too bad if you have a wiring diagram for both trucks. also you will need the plug and dash for the moon cluster. on a side note if you need a cluster and plug I know I have a cluster and may have the plug. you can have them just pay the shipping.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-31-2014, 08:13 AM   #4
Nate.n.1989
Ok, sounds good, would you happen to know where I can get my hands on diagrams for each? I've searched all over the net and can't find any
Old 08-31-2014, 03:04 PM   #5
91ChevyZ71
For a 1991 Chevrolet C/K
Instrument Cluster Connector 34 Pin Connector
O - B is bottom row - Has semi-circle "cut-outs" on edges - I thik for connector - Been a while.
B Wire(s) Colors Circuit Function
17 Brown 437 ECM/PCM
16 Light Green/Black & Light Gray/Black 822 VSS - Low
15 White 121 Gauge - Tachometer
14 Brown 250 Ignition & RWAL
13 Purple/White 821 VSS - High
12 White 696 RWAL
11 Black/White 450 Ground - Gauges - 10 amp
10 Not Used Not Used
9 Not Used Not Used
8 Not Used Not Used
7 Not Used Not Used
6 Not Used Not Used
5 Not Used Not Used
4 Not Used Not Used
3 Light Green & White 11 Headlamp Dimmer Switch & DRL
2 Gray 8 Fuse Block
1 Black 150 Ground
B
O
VSS - Vehicle Speed Sensor
DRL - Daytime Running Lights
A Wire(s) Colors Circuit Function
17 Not Used Not Used
16 Red/White 818 Cruise Control
15 Yellow 237 Safety Belt Warning Lamp / Buzzer
14 Dark Green 35 Gauge - Engine Temp Sender
13 Tan 31 Gauge - Oil Pressure Sender
12 Not Used 507 Not Used
11 Not Used Not Used
10 Light Blue 14 Turn Signals
9 Pink/Black 39 Power - Fuse Block
8 Dark Blue 15 Hazard Flashers
7 Light Orange/Black 419 DRL Module
6 Tan/Black 592 Upshift Indicator Lamp
5 Brown/White 508 ECM/PCM - Check Engine
4 Not Used 69 Not Used
3 Brown 25 Gauge - Ammeter (Generator)
2 Tan/White 33 Parking Brake - RWAL - Brake Pressure
1 Purple 30 Gauge - Fuel
A
RWAL - Rear Wheel Anti-Lock Brakes
Sam
2014 GMC Sierra SLE K1500 Z71 Fire Red Regular Cab
Long Bed - 5.3L (325 Cu In) V8 - 6L80-E 6-Speed Auto
1991 Chevrolet K1500 Z71 Silver Regular Cab - Long Bed
5.7L (350 Cu In) V8 - 4L60 4-Speed Auto
91ChevyZ71 is offline   Reply With Quote
