Old 08-29-2014, 11:47 PM   #1
79Betty
79Betty's Avatar
Question 14 Bolt 10.5" Full-Floater Rebuild
Does anyone know of a thread of a how-to rebuild a 14 bolt ff? I tried ser hing but that didn't work out worth a crap. I beed to rebuild, add a locker and regear my 14 bolt. I want to do it myself but would like a guide. Also, i want to add a rear locker, been thinking of a detroit true-trac, is it locked my axle-shafts full time? This will be more off road than onroad... Ler the advice begin!!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 08-29-2014, 11:51 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: 14 Bolt 10.5" Full-Floater Rebuild
http://www.pirate4x4.com/tech/billavista/14b_bible/
They call it the 14 bolt bible for a reason
Good luck!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 08-30-2014, 01:36 AM   #3
jlk
http://www.fourwheeler.com/how-to/tr...rebuild-parts/
jlk is offline   Reply With Quote
Old 08-31-2014, 12:34 AM   #4
79Betty
79Betty's Avatar
Thanks for the links guys, 2nd one has the spes and first lotsa part numbers... Guess i'ma just start taking pictures while i disassemble it. Start with the hubs and work my way in!!
Old 08-31-2014, 03:29 AM   #5
wilkin250r
wilkin250r's Avatar
Just keep in mind, it looks much easier than it really is.
There are relatively few parts inside them, mechanically they are very simple. But the setup is no joke, it really does need to be that precise. You cannot just slap it together, you really do need to take the time and all the measurements, yes with a proper dial indicator, and get it exact.
Thankfully, the 14-Bolt is a little more forgiving than other axles, with threaded bearing preloads and such, but it still requires attention to detail (EXACT DETAIL) to be set up properly.
Just don't make the mistake of thinking "this is simple, there's only a handful of parts inside here". I've known guys to remove and install the carrier five, six, seven times, changing one and two thousandths of an inch, to get the correct gear mesh pattern.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 09-01-2014, 09:06 PM   #6
79Betty
79Betty's Avatar
Thank you wilkin for the reminder. I have been reading, and after i disassemble it i could awlays take it to our highschool shop to fix it. They have 1 tech for every 4 kids in a 20 kid class. The tech's know their stuff. Anyway the back end spins good so right now going to just pop the cover off and shafts out see how it looks, redo brakes and seals, but can anyone recommend a good locker? Turning 40" tires on pavement and dirt, and will need to withstand burnouts... Thanks!!
14 bolt, 14 bolt ff, detroit
