Old 08-10-2003, 05:24 AM   #1
SEVEND2
SEVEND2's Avatar
Needed: pics and info on lowering..
Coil rear suspention and blocks,, need pics of what it looks like under neath and a side shot of truck
so i can see what it might look like
size of blocks you used and etc
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 08-10-2003, 08:15 AM   #2
Gene
Gene's Avatar
3 inch blocks, sorry I dont have a shot of them under truck.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-10-2003, 03:18 PM   #3
redone71
redone71's Avatar
You can see a picture of a two inch block installed at the web site below
http://www.classicperform.com/goingdown6772.htm
On the eighth day, he made trucks and saw they were good.
redone71 is offline   Reply With Quote
Old 08-10-2003, 03:49 PM   #4
treefrog
Gene
Can you tell me what the height is from the ground to the center of the whell opening arch, front ans rear? That's about the stance I'm after, and I need so see what blocks to buy. Thanks. TF
treefrog is offline   Reply With Quote
Old 08-10-2003, 06:56 PM   #5
Gene
Gene's Avatar
Front measures 28 inches rear is 29 1/2 with 3 inch blocks and one coil cut from the front springs, on 295/50/15 inch rims.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-10-2003, 08:26 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Gene, I love that stance man!. Just right!!!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-11-2003, 01:00 AM   #7
pissonNOS
senior member
pissonNOS's Avatar
Gene how much is your front lowered?
69 GMC bagged
pissonNOS is offline   Reply With Quote
