Old 08-30-2014, 04:09 PM   #1
grs
Flushing cooling system >.
I want to get my cooling system flushed. I thought the thermostat had to come out to get the block flushed. Is that true? I want to pay someone to do it. It is a 327.
grs is offline   Reply With Quote
Old 08-30-2014, 06:48 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Flushing cooling system >.
You don't need to remove the T stat to flush it out. It just needs to be up to temp for it to open to flush the system.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-30-2014, 06:54 PM   #3
DLW
Depending on the flush procedure it may not need to be removed. If you use one of those kits that you install on the heater hose that you use with a garden hose, it's beneficial to remove the thermostat so it won't close once the colder water enters from the hose and your assured that you are flushing the block out good.
DLW is offline   Reply With Quote
