Need pulley part numbers for K20 with A/C, PS, PB, Smog pump
I accidentally posted this in the suburban section and maybe the mods could delete that one
I have a CA burb that I am having trouble with the pulleys lining up. As you can see I have a 3 groove crank and 3 groove WP pulleys but I think the upper is incorrect. ![]() I checked my brothers 69 C20 which is also a CA, PB, PS, A/C, Airpump truck and his lower pulley is a 4 groove with the upper being a 3 groove. As far as I can see: first groove is the WP/ALT/Crank second groove is A/C third is Smog Pump fourth is power steering pump Is the belt routing the same for 72 and 69? Is 72 also supposed to have a 4 groove lower? Anyone have pics of the factory setup and some part numbers? Thanks |
