Old 08-30-2014, 05:05 PM   #1
Mike c 10
Mike c 10's Avatar
Helpneeded with manuel Shifter 1966 c 10
hello
Hope you can help me ..Ive a 1966 c 10 with manuel Transmission . the shifter sits on the steering colum . When I drive sometimes I can manage the gears only the first vgear will goo or only the second .or only rear .. I think the part that sits on the steering colum in front of the Firewall didnt work so god. I dont know what the Name of the part Maybe someone can help me or have one of those parts... Many thanks !!!
Mike c 10 is offline   Reply With Quote
Old 08-30-2014, 07:42 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Helpneeded with manuel Shifter 1966 c 10
I would recommend decreasing the column and getting all the black gunk off. Then you should be able to see better. Make sure the 2 arms are parallel when it is in neutral. There is a hole in the middle part that will allow a drill bit or nail to go through all 3 parts. If it will not un clip the linkage and adjust it until it does. Once you get it lined up you cam lube it with white spray grease. My 3 speed shifts with 1 finger.
Jurassic-1 is offline   Reply With Quote
Old 08-31-2014, 02:56 AM   #3
Mike c 10
Mike c 10's Avatar
Hey Jurassic-1
Thanks !! I ll try that would be glad when I also can shift with one finger !!
Mike
Old 08-31-2014, 08:18 AM   #4
Mathew21
Mathew21's Avatar
Mike c 10 you have a Beautiful truck! How much drop does it have?
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 08-31-2014, 05:04 PM   #5
Mike c 10
Mike c 10's Avatar
Hello Mathew 21
thanks!! I got this c 10 a few weeks ago and it came like it is ... I has 15 Inch steeles ..Iin the rear I has LJ Wrangler lowering springs with shorty Shocks...front could be cut the coils maybe one ring....
I haven´t take measure..but I agree with you..it Looks good..
Mike
