Old 08-30-2014, 05:47 PM   #1
dwcardfan
dwcardfan's Avatar
Will 1981 Camaro column fit
I have a tilt column leftover from my Camaro build and was wondering if anyone has used that in our trucks. It is a 81 Camaro column and I have a 65 fleetside that had a powerglide in it. I am putting a 5.3 and 4l60e in it. Thanks for the help.
dwcardfan is offline   Reply With Quote
Old 08-30-2014, 09:31 PM   #2
pdxhall
pdxhall's Avatar
Re: Will 1981 Camaro column fit
I'm not sure of the 81 Camaro column but I picked up a 73 Camaro column and it fits perfectly. I had to take off the floor mount that is tack welded on the column off but then the length and diameter are spot on. I haven't checked on the mounting to the underside of the dash yet.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-31-2014, 10:37 AM   #3
dwcardfan
dwcardfan's Avatar
Thanks PDX
