Old 08-30-2014, 05:49 PM   #1
ls64
mustang II
Has anyone used the Fatman front end or the universal crossmember that Speedway sells made by Hiedts? I just can't offered the other alternatives. If anyone has another option I am all ears.
ls64 is offline   Reply With Quote
Old 08-30-2014, 08:12 PM   #2
PGSigns
PGSigns's Avatar
Re: mustang II
Any reason you dont want to work with the front end in the truck now? Easy to upgrade and parts are easy to come by.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-30-2014, 08:41 PM   #3
ls64
Re: mustang II
Weight!! I am trying to make it a light as I can afford.
Old 08-31-2014, 01:01 PM   #4
LVPhotos
LVPhotos's Avatar
Re: mustang II
All the parts are similar, so your not saving any money. I did cost analysis for my 62 and after full build the new Porter built stuff is not much different in price. Still need upgrade brakes and column, joints and so on. By the way I opted on 13 inch brakes came in at 60lbs each side with spindles.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
