Old 08-30-2014, 06:57 PM   #1
ellisjay2
long wheel base two piece drive shaft replace...
My center support and u joints are worn causing the vibration and clunk noise when shifting I've been aiming to save a few dollars since $300 is average price round town at local shops to rebuild and balance....I was thinking to find a used one in decent shape and put on new center support...should I go to junk yard/ I've found a couple on craigslist but their out of the way......Name:  20140308_131933.jpg
ellisjay2 is offline   Reply With Quote
Old 08-30-2014, 08:31 PM   #2
Rubble
Re: long wheel base two piece drive shaft replace...
Why don't you just rebuild it yourself? U joints are pretty easy to do & the steady bearing is usually not bad.You shouldn't need to rebalance the driveshaft after doing U joints,I've never had one done & been driving & repairing these trucks over 30 years.It's a crap shoot at the wrecker finding both u joints & a good steady bearing.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 08-30-2014, 08:36 PM   #3
Just call me Sean
Just call me Sean's Avatar
Plus they always bend the driveshafts with the forklift.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-30-2014, 09:28 PM   #4
meatwagon83
meatwagon83's Avatar
advance or napa have the carrier bearing and u-joints, i did mine last year
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 08-30-2014, 09:47 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Cost me $150 to have a 1 piece made to replace my 2 piece.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-06-2014, 03:58 PM   #6
lgvl
lgvl's Avatar
I have an 82 8' 3+3, with a two piece drive shaft like yours, and just unmounted the drive shaft myself and took it into my local NAPA, which has a machine shop, when the bearing cups wouldnt press out. Cost me just over $110 i believe for all the labor and materials. I had them replace the carrier bearing as well as all the u joint bearings. I wouldnt worry about the balance, just replace the bearings then reinstall. If you still have vibrations, then take it in to be balanced.
'82 C30 3+3 Dually 454
lgvl is offline   Reply With Quote
Old 09-07-2014, 06:47 PM   #7
ellisjay2
Got my carrier bearing and set of u joints done this weekend thanx to advice and help from others. The challenge that delayed me most due to circumstances was not having a vice for stability. But having a creative mind and improvising with mechanical comprehension I was able to use an object as a temporary vice.Attachment 1299127 Old ujoints out busted up........
Busted carrier bearing......
Old 09-08-2014, 07:31 PM   #8
ellisjay2
Originally Posted by ellisjay2 View Post
Got my carrier bearing and set of u joints done this weekend thanx to advice and help from others. The challenge that delayed me most due to circumstances was not having a vice for stability. But having a creative mind and improvising with mechanical comprehension I was able to use a wall shelf, jack and wood as a vice.
Old busted joints
Attachment 1299129
I came up with idea to use jack and wall shelf to vise drive shaft while prying off old carrier bearing ring with crow bar and hammer......then I used the same method to press out old and new u joints....
Attachment 1299128
Attachment 1299130
Attachment 1299131
Attachment 1299132
both new sets pressed and sealed.
Rented bearing press tool from autozone for $115 full refund after return, joints were $20 for set, carrier was $30 at oreilly auto parts...truck rides a whoooole lot better!!!! Thanx gm comrades.
Old 09-08-2014, 08:21 PM   #9
meatwagon83
i know it made a world of difference on mine!
Old 09-10-2014, 08:51 AM   #10
MalibuSSwagon
Damn I need to do this on the C10, my 2 piece shaft is looking rough.
MalibuSSwagon is offline   Reply With Quote
