Old 08-31-2014, 08:49 AM   #1
Neatbeard
Neatbeard's Avatar
Will a 350ci motor be a straight swap for inline 6?
Hi guys.
Dumb question probably, but I currently have a 66 SWB stepper with a hi torque inline 6 and manual 3 on the tree.
Would I be able to take the inline 6 out and fit a 350 in its place with no modifications?
Will it fit the manual 3 speed?
Will it fit the existing motor mounts?
etc etc.
Thanks in advance.
My old truck:
'66 Shortbed Stepside - Ex USAF - Shiny and new on the inside & underside, original patina on the outside. - http://67-72chevytrucks.com/vboard/s...d.php?t=487701
Tattooed pinstriper and graphic designer with an awesome award winning beard! Check me out at http://www.vontash.co.uk
Neatbeard is offline   Reply With Quote
Old 08-31-2014, 08:57 AM   #2
pimpston65
pimpston65's Avatar
Re: Will a 350ci motor be a straight swap for inline 6?
Originally Posted by Neatbeard View Post
Hi guys.
etc etc.
Thanks in advance.
to my knowledge the back(trans side) on a L-6 (292) will accept all trans forms i.e. auto,manual, so the V-8 will mount up to the same trans forms. the motor mount on the L-6 is very simular, meaning the drivers side is exactly the same on V8, but the pass. side is a bit different and will need to be switch to V8 perch to fit the crossmember. you also will need to switch the clutch pivot ball from L-6 to V8 type... thats all i got. why are you switching, if you dont mind me prying???
pimpston65 is offline   Reply With Quote
Old 08-31-2014, 09:08 AM   #3
Neatbeard
Neatbeard's Avatar
Cheers for the info. I've always loved V8s and all my mates over here are getting better fuel economy and at the same time are still faster, have better performance, etc. I'm just thinking aloud at the mo.
My old truck:
Old 08-31-2014, 10:08 AM   #4
Greg63
Enjoy your truck
Greg63's Avatar
I swapped out my 230 L-6 for a 350 V-8 without any real issues.
Both motor mounts bolted right up to the 350 and the trans mated perfectly to the 350. There were no crossmember clearance issues at all.
I am still using my L-6 clutch pivot linkage assembly.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 08-31-2014, 10:12 AM   #5
Lugnutz65
Lugnutz65's Avatar
Pimpston65 is correct but I will add some info. If you have a 230ci or 250ci then you already have the correct engine perches. If you have the 292, then one of the perches is not correct for the swap and you will need to find one..
The L6 mechanical clutch uses a Zbar that mounts to a bracket that comes off the side of the engine block. Your V8 might not have a place for that bracket to mount, so keep that in mind. As far as the V8 swap goes, it is one of the most common modifications for these trucks and a quick search in the FAQ section or the build thread section should get you the details required for any questions. Good luck. For me, I'm staying with my half dozen.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-31-2014, 10:15 AM   #6
Dans66Chevy
230-250 six has the same mount location as a small block. The 292 is the only odd ball on the motor mounts. Passenger sits forward a few inches. A transmission from a 230 six will bolt up to a 454 they are all the same.
Dans66Chevy is offline   Reply With Quote
Old 08-31-2014, 02:56 PM   #7
Neatbeard
Neatbeard's Avatar
Thanks for the answers guys. I should've said that my motor is a 250 inline 6.
My old truck:
