Old 08-31-2014, 10:40 AM   #1
grs
How much antifreeze in radiator?
I drained my radiator on my 64. It has a 327. Some antifreeze came out of the engine. I installed a new stat in it. Only about 5 gts came out of it. Is that about all there will be in the radiator?
grs is offline   Reply With Quote
Old 08-31-2014, 11:08 AM   #2
69chevytrucker
69chevytrucker's Avatar
Re: How much antifreeze in radiator?
run it for a few min with the cap off rev it to 1500 to 1700 it will suck the coolant down and around your cooling system and your heater core while its doing that pour more coolant in till your full run till stat opens and does a cycle if there is and air left in the system it will burp it out
69chevytrucker is offline   Reply With Quote
Old 08-31-2014, 12:21 PM   #3
T2vigil
T2vigil's Avatar
I drill a 1/16" hole through the T-Stat. This will allow the air to escape for easier filling without the motor having to be heated up.
T2vigil is offline   Reply With Quote
Old 08-31-2014, 12:22 PM   #4
LVPhotos
LVPhotos's Avatar
I got 2 gal h 20 and 1 gal antifreeze in my 1962 stock radiator after getting it fixed. I like more water, around 25 to 30 percent. For desert heat water cools faster. Doesn't get freezing cold often enough to have to change mix. The diesel is 50/50 for travel.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-31-2014, 06:38 PM   #5
69chevytrucker
who told you that load of crap it is called antifreeze/engine coolant it has properties that make it cool way faster then water
Old 08-31-2014, 07:27 PM   #6
LVPhotos
LVPhotos's Avatar
That would be the man who owns the shop and builds radiators. Water dissipates heat faster than antifreeze. Read chart on bottle. Water by itself is not great it needs some properties of coolant additives for pump seals.
