![]() Join Date: Mar 2012
rear springs info
MOOG-CC603 variable rate
MOOG-6101 constant rate which one to use as replacements and what is the difference in a constant and variable rate spring??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
