Old 08-31-2014, 02:47 PM   #1
king drake
Hatch handle installation
I need help installing hatch handle,I disassemble hatch last year,I can't remember how to put back.
king drake is offline   Reply With Quote
Old 08-31-2014, 08:07 PM   #2
Dale99
Re: Hatch handle installation
Are you needing step by step, or would a picture work?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 08-31-2014, 11:06 PM   #3
king drake
Picture would be good,thanks.
Old 09-01-2014, 09:01 AM   #4
Dale99
I went to take a picture, and found out I don't have mine back together yet. Thought I did?
Bump so hopefully another board member will post one.
Old 09-01-2014, 03:45 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-02-2014, 09:22 PM   #6
king drake
Great! Pictures BobbyK,thanks a lot.
Old 09-02-2014, 09:24 PM   #7
king drake
Thank anyway,Dale99.
Old 09-08-2014, 08:21 AM   #8
Senorx
Senorx's Avatar
Does the hatch need to be separated or split open to install all the guts and handle? I have a pretty decent hatch with glass and no handle or guts. I also have a slightly cracked hatch with no glass and all the guts and handle. Just trying to figure out if I should just swap handle and guts or if it's just too much of a hassle.
Senorx is offline   Reply With Quote
Old 09-08-2014, 08:44 AM   #9
Dale99
No, Ive pulled and installed the handle n stuff many times w/o separating it. There is a metal plate that all this screws to that is riveted to the fiberglass that stays in it.
Old 09-08-2014, 09:06 AM   #10
Senorx
Senorx's Avatar
You didn't happen to document the process with pictures?
Old 09-08-2014, 12:17 PM   #11
Dale99
No, sorry
1994 s10 blazer 4x4
Old 09-20-2014, 09:44 PM   #12
BobbyK
BobbyK's Avatar
All the guts and linkage rods can be fed in through the access hole.
