08-10-2003, 10:37 AM | #1 |
Pf35 Oil Filter
I went to get some oil filters the other day and they didnt have any AC Delco PF35's. So i asked if they had any and he said they were discontinued. WTF.. The guy said they were replaced by the PF1218 and the PF35L. The 1218 is $4 and the 35L is $10..
So whats the difference between the two? The look exactly the same.. Ive been using the the PF35 for 21 years! I like the PF35! I want my PF35 back!!! Randy
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-10-2003, 10:43 AM | #2 |
Robert Olson Transport
shop around and buy a couple f cases of the pf35s im sure therye around somewhere yet
08-10-2003, 11:06 AM | #3 |
Fabricate till you "puke"
I run the 1218s on my sb. what I have been told is that they are the same filter as the pf35, but have an antidrainback valve added. im not sure on the pf35L, but I think it may be a "longlife filter"? As often as I change oil & filters, i couldnt see paying $10 for a filter. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-11-2003, 12:14 AM | #4 |
Same thing with the fram PH13. Some chainstores won't stock 'em. Now I use the Wix 51061 or Napa 1061. Same size, better filter.
08-11-2003, 12:27 AM | #5 |
Low & Slow
The PF35L is a "long" filter. I use them on my truck because that's the first thing i see at the local auto zone.
70' C-10 LWB Fleetside 4.5/6 drop |
08-11-2003, 01:54 PM | #6 |
14.1 @ 96MPH
Actually, IIRC, the PF35L is a synthetic-element filter; hence the $10 cost instead of $3. Think Mobil1 filter. The PF1218 is just the PF35 with an anti-drainback valve, and is the standard filter for newer smallblocks with proper clearance (my mom's '97 Suburban used one). I think the long filter is the PF45. Could be wrong on that, and maybe the 35L is long and synthetic!
Project1970 - LS1 Swap Complete! |
08-11-2003, 04:10 PM | #7 |
Active Member
You are exactly right Project1970, PF35 and Pf1218 have the exact same media pack in them. I work for a filter company.
Paul |
08-11-2003, 05:02 PM | #8 |
I use a Hastings LF226. It's the 2 quart version.
08-11-2003, 06:31 PM | #9 |
sooo..The PF35L is synthetic filtered. =$10.
And the PF1218 is paper filtered with antidrainback valve. =$4. Correct?? Pf25 is the short filter. Randy
08-11-2003, 07:48 PM | #10 |
I need the Pf25 because I have very little clearance around the headers, but I cannot find it anywhere. Does it have an ACDelco equivelant or do I have to get another brand?
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
08-11-2003, 09:23 PM | #11 |
I like the Napa Gold 1061 and have used them on my Blazer for years. They seem to be the best bang for the buck.
08-11-2003, 11:17 PM | #12 |
My local Farm and Fleet is the only place I can fin AC parts. The PF35 is the regular media filter and is called Duraguard and the PF35L is the synthetic media and called Ultraguard, I've got a 35L on the Blazer right now since they were all out of regular 35's. You can order off Delco's website too the last time I checked.
08-11-2003, 11:38 PM | #13 | |
14.1 @ 96MPH
I prolly should've mentioned it. If you want a cross-reference for all brands...use the 1994 (or 1993-1997 for that matter) Camaro Z28. The PF25 is used there because there is NO room under that thing.
08-12-2003, 05:56 AM | #14 |
Would I want a synthetic filter for synthetic oil? I'm using Valvoline Syntech 20w50. Or is filter medium irrelevent to type of lubricant?
08-12-2003, 06:54 AM | #15 |
Low & Slow
Thanks for clearing that up for me project1970. I wan't trying to give out wrong info.
08-12-2003, 11:17 AM | #16 |
Uh yeah I know that the Pf25 is ACDelco. I re-read my post and I realized I worded that wrong. I thought maybe they got rid of it at the same time they got rid of the Pf35 because I can't find it at both the parts store that I knew used to carry it. I thought maybe they got rid of it and used another just like they did with the 35 going to the 1218.
