Old 08-31-2014, 06:56 PM   #1
dell72
rock auto gas tank?
I'm looking to buy a new gas tank for my 69 SWB stepside. I found a spectre (sp?). They list for about $150.00. I was set to order it but the notes said no filler neck included. Is this true or a typo? Has anyone ordered one of these tanks? Thanks.
dell72 is offline   Reply With Quote
Old 08-31-2014, 07:10 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: rock auto gas tank?
just looked it up saw same thing im thinking they are talking about the rubber gromet at the top
69chevytrucker is offline   Reply With Quote
Old 08-31-2014, 07:14 PM   #3
69chevytrucker
the other one the platinum one says it has it all even the rubber
Old 09-01-2014, 11:18 AM   #4
twouvakind
twouvakind's Avatar
Filler neck is included. Bought one for my 72, couldn't be happier. If you need to filler neck grommet be sure to procure it from board vendor Wes at Classic Heartbeat.
twouvakind is offline   Reply With Quote
Old 09-01-2014, 11:23 AM   #5
dell72
Cool! thanks for the info
Old 09-01-2014, 01:29 PM   #6
In The Ten Ring
I considered the spectre but ended up getting my old tank renewed.
In The Ten Ring is offline   Reply With Quote
Old 09-01-2014, 01:48 PM   #7
dell72
My current tank is rusty inside. I figured a new one will save a lot of hassles
Old 09-01-2014, 06:19 PM   #8
Scottcoda
Scottcoda's Avatar
Most tanks are made overseas and not always a perfect fit.. The spectre tank is made in Canada and fit perfect. Which was the deciding factor in my purchase a little over a year ago. The price with the 5% discount code found on this forum made it a real no brainer. Not sure why anyone would repair an old tank when the spectre can be at your door for a good amount under $200.00.. Buy the spectre and have no regrets.. Just make sure you get some water based lub to assist when installing it with the grommet. I used astroglide.. Just make sure you tell your partner why you have it.. Her finding astroglide in the cab of your truck might cause some unwanted issues
68 GMC 2500 stepside LWB 250CI
Scottcoda is offline   Reply With Quote
Old 09-01-2014, 10:48 PM   #9
In The Ten Ring
I renewed my old tank because I wanted to save it if I could. I go with original parts whenever possible as a matter of course and that was an original part.
I also didn't know if the spectre tanks were perfect fits and I knew my old tank certainly was.
To the original poster: if money if the main factor, and spectre tanks fit as the above-member has promised, then a spectre tank will be the better choice.
Old 09-01-2014, 11:11 PM   #10
Scottcoda
Scottcoda's Avatar
I absolutely agree with what you said.. I should have clarified about the condition of my tank when I got it from the P.O.. If the tank did not have small holes and poor attempts to fix them I prob would have cleaned the tank and tried to sealed it.. Original is the way to go all day long but in my situation a new in the cab tank for sure was the way to go.. Fuel headaches are no flaming joke
Old 09-02-2014, 02:31 AM   #11
In The Ten Ring
Of course you agree Scottcoda, because great minds like ours think alike.
My tank had flash rust was all. The radiator shop owner told me my "tank was much better than most he gets in there."
Once I get some repairs to my house caught up I hope to get back on to my truck's fuel system. Once those new lines are (finally) in I can put the tank back in, followed by the seat, the cab to frame bushings, bleed the brakes, but the new radiator in, and it's off to the DMV for a license.
So Scott, you have a long wheel base stepside? Those are so cool!
