08-31-2014, 08:38 PM | #1 |
throttle pedal and cable for 65 c10?
anyone know which one to get i eliminated the old linkage crap and now i need the pedal with cable and hardware for my 5.3 swap. anyone know where to get one? i been looking throughout this whole forum and all i see is for 68 and up... thanks in advance
09-01-2014, 12:46 AM | #2 |
Re: throttle pedal and cable for 65 c10?
Starting at port 110 Mark shows how he adapted a cable throttle pedal from a 71 - 72 C10.
http://67-72chevytrucks.com/vboard/s...le#post5286113 Post 41 shows a Lokar pedal ... http://67-72chevytrucks.com/vboard/s...le#post6284534 Post 668 shows another one. http://67-72chevytrucks.com/vboard/s...le#post6611436
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
09-01-2014, 04:36 AM | #3 |
I went to pick n pull and yanked the pedal assembly and cable from a late 70-early 80's ish chevy.
I used the post referenced above to aid on the changeover, though on my 66 things lined up a smidge different. If you go the junkyard route, make sure to also nab the bracket that holds the carb side of the cable, the one I have bolted to the intake manifild, looks like it also has a spot for a kickdown levercable/whatever to mount, but mine is a manual tranny. I did the gas pedal changeover plus reinstalled my MIP floor mat correctly ( PO had done a horriblr job, totally misaligned) and installed retracting seat belts for deiver and passenger, then mounted 2 old belts in middle so kids could have belts, and it took a total of about 7 hours for all 3 projects. |
