Old 09-01-2014, 12:41 AM   #1
BCOWANWHEELS
Maintenance time some help please
I HAVE TO FIX MY TILT STEERING COLUMN.it moves freely up and down and the lock in position dont do anything. could somebody tell me exactly what i have to do to fix this problem ? does the column have to be removed from the truck ?
second question please,
I have to change the dash pad on my dash,my truck is a factory a/c cab. what all do i need to do to change it out ?
all help guidence is greatly appreciated.
regards
old man bob in tn.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-01-2014, 01:18 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Maintenance time some help please
Bob- 1. Send your column to KevsClassics for a restoration, you won't be disappointed.
2. Remove all your AC hoses in the cab, glovebox liner, radio, gauge cluster, and use a flex head 3/8 gear wrench to remove and reinstall a dash pad. When reinstalling, tighten the nuts "finger tight" or your pad will look wavey across the top if the mounting points are cinched down.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
