09-01-2014, 12:35 PM | #1 |
Radiator support not level with frame.
I recently changed out my radiator support mounts.As I stated in an earlier post I tried jacking the passenger side of the support with a jack to try and get the old rubber out,not a good idea.I took the mounting brackets off and changed them that way ever since it has not looked right,So since I have the motor out and setting on jack stands front frame horns level I removed the new support mounts and the drivers side has weight on it and the passenger side has none the support its self is about a quarter to three eights out of level.
09-01-2014, 12:44 PM | #2 |
Re: Radiator support not level with frame.
Measure from the ground and record the measurement at the top of the frame horns. Do the same with the core support cushion mounting brackets. What is it? Have you placed a level across the frame horns? Have you placed a level across the frame at the back? These old work horses have been through a lot and it's not uncommon for there to be some frame twist.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
