Old 09-01-2014, 02:01 PM   #1
mechanic350
mechanic350's Avatar
Suspension change out
ok so my 72 swb fleet side is currently lowered with csp lowering spindles up front and single leaf out back. I'm thinking about taking it back to stock height for practicality for my upcoming move to washington. anyone have any takes on how difficult this would be. i don't want to swap out the spindles i have because i just upgraded my brakes to wilwoods all around. anyone who knows anything that can help would be great.
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline   Reply With Quote
Old 09-01-2014, 02:11 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Suspension change out
Lowering spindles are a solid platform, and even with the stock front springs back in there will keep it dropped down whatever the offset is on the spindles.
More leaves in the rear will stiffen the rear back up and also raise the rear end up.
What part of Washington you moving to? I see you're currently in SD... in the Navy? Moving to Whidbey, Bremerton or Everett? I'm located up on Whidbey Island.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-01-2014, 02:39 PM   #3
mechanic350
Im going to be heading to bremerton for a change of homeport. yeah i think if i put stock type leaf springs and new shocks in the rear and maybe a 2" lift spring in the front it will lift the front back up and offset the lowering spindle. with new shocks up front too. shouldn't be too hard of a change out.
Old 09-01-2014, 03:52 PM   #4
sKnNyPpY
sKnNyPpY's Avatar
My little brother is a Nuke on the Nimitz, I think he's in Bremerton right now. Are you hauling or towing up there? I find my LWB with a flip still rides better loaded but I'm taking short trips. Replacing my stock leafs after the flip (I was too low) only took a day by myself, and I replaced the ball joints after doing the spindle/drop in the front in a day, too. I still wouldn't look forward to redoing the work again. Safe travels and say hi to Stephen Stockard if you meet him!
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 09-01-2014, 03:58 PM   #5
mechanic350
Nice I'm a nuke on a sub. lol. ill be shipping the truck up there. can't drive 2 cars at once. the truck rides great with the mono leaf rear suspension i have right now. thanks. i will.
Old 09-01-2014, 04:04 PM   #6
sKnNyPpY
sKnNyPpY's Avatar
Keep it low and get a cheap 4x4 or Soobaroo for the trails. From what I hear the roads are real nice and it won't matter if you are higher in the snow with our rwd, limited slip or not.
