Old 09-01-2014, 07:35 PM   #1
67JimmyMO
67JimmyMO's Avatar
67 GMC-Factory Exhaust Hanger Brackets?
My 67 GMC SWB has 3 brackets with a hole (pictured below) attached in various spots down the drivers side frame rail.
They are all riveted to the frame so I assume they are OEM.
I am converting to V8 and building my own exhaust (Heartbeat 2 1/4" w/Flowmaster clone muffs) and was wondering if trucks with duals from the factory had the same pieces running down the passengers frame rail?
If so, do any of the truck parters ever cut those off and sell them?
1967 GMC SWB 383 Stroker w/Saginaw 4sp
1979 Chev C30 Scottsdale Flatbed 350 4sp
2000 Chev 3500 Flatbed 454 Automatic
1978 GMC 6500 Flatbed Dump 366 5sp + 2sp
1965 Chev K10 LWB 230 4sp
1985 Chev K30 Flatbed 350 4sp
67JimmyMO is offline   Reply With Quote
Old 09-02-2014, 04:55 PM   #2
airdale94
airdale94's Avatar
Re: 67 GMC-Factory Exhaust Hanger Brackets?
I don't think any trucks came with factory duals.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-02-2014, 05:47 PM   #3
davepl
davepl's Avatar
My 402 truck has them on both sides. Factory rivets. No idea if it had duals from the factory (not on the SPID). I've been told in other threads that some trucks had dual exhaust though. Maybe it was only big blocks or something.
In a tangential note the base 427 available in the '69 Impala SS was a single 1.5" pipe. Ouch.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-02-2014, 06:56 PM   #4
67JimmyMO
67JimmyMO's Avatar
I wondered about that.
Seems like there is a SPID pic thread here somewhere, I will try to look through it if I can locate it.
Old 09-02-2014, 06:59 PM   #5
67JimmyMO
67JimmyMO's Avatar
Do you remember if it has the same (or similar) brackets as my pics?
Wow, 1.5" single for a 427?!?
