Old 09-01-2014, 10:04 PM   #1
davepl
davepl's Avatar
Idle Vacuum - How much?
With a good large 2" gauge I'm seeing 15inHg of vacuum on my stock rebuild 402 at idle around 600-700rpm.
Since its a stock cam, I was expecting more. It runs fairly smooth, not perfect. The needle is steady, doesn't move more than 0.5" and doesn't bounce around.
What would be normal for vacuum on one of these? Or is it?
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-01-2014, 10:08 PM   #2
steveo3318
steveo3318's Avatar
Re: Idle Vacuum - How much?
That's pretty good. Best I can get is 10 to 12 in my 385 stroker with a 296/304. 510/510 cam. I would be ecstatic with 15
steveo3318 is offline   Reply With Quote
Old 09-01-2014, 10:09 PM   #3
davepl
davepl's Avatar
Well yeah, but I need to know what's normal for a stock cam. Not a 296/304 advertised duration cam!
The internet says 15-20. I'd rather have 20.
Old 09-01-2014, 10:12 PM   #4
71 super
71 super's Avatar
Both of my bb are at 15-18 in. Vac., it is more than plenty to run all the a/c vac and brakes as well as the cruise on my 71- it is at 18.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-01-2014, 10:21 PM   #5
davepl
davepl's Avatar
This page
http://www.gregsengine.com/using-a-vacuum-gauge.html
...says that a steady 14-16 inches of vacuum indicates "incorrect ignition timing". My guess at timing is really a crapshoot. I think I'm at about 10 degrees initial right now (vs 4-6 with the old original fuels).
How do I know what's the best initial timing? When I was a kid I'd just run as much advance as I could without pinging or making it hard to start, but there's no doubt a more scientific approach.
Old 09-01-2014, 10:56 PM   #6
jmorri34
jmorri34's Avatar
Best I can get on my stock 350 is 15 and Im not losing any from what I can tell, no leaks at least and Ive tried everything I know how to get more! not like I need it but thats what I have anyway!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 09-01-2014, 11:06 PM   #7
Lattimer
Lattimer's Avatar
I'm running a small block with a moderate street cam (lopey idle), and I get 15 inches at idle. Initial timing is 14 degrees for me, and it runs great with no ping. I do have my vacuum advance on the manifold, which makes a huge difference in my idle.
Probably doesn't help much with your big block, but with a stock cam it seems like you would have 18 inches easily. I'd push the timing up a little and see if it helps. Carb adjustments have an effect on idle vacuum as well.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 09-01-2014, 11:47 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
It may vary by type of engine. I don't have a full-time Vacuum gauge on the 350 V8 in my '71 Jimmy, so I don't know what is normal for an SBC, let alone a BBC.
My ['68 C/10 Stepside] L6 292 with a 260H Crane Cam pushes 17 inches of mercury at normal operating temp with 850 RPM at idle. I recently had an exhaust valve spring break and after I replaced it with another ''used-good'' spring my Vac was reading 16"Hg. That's good enough until I can pull a major tune-up.
