08-10-2003, 01:50 PM | #1 |
HEI BATT hookup help
Whaqts the best place to hook up the power with key to ? For my eletronic ignition
Soon to have 68 SWB 350 with Turbo350 |
08-10-2003, 01:56 PM | #2 |
its all about the +6 inches
On your fuse box there is a terminal that should read IGN UNFUSED. This is everyone's favorite place.
The large pink wire on the back of the ignition switch is also an ideal place. My fuse box was getting full and my large pink wire was already wearing a crimp-on connector, so I did it. Many of the magizines claim that the fuse box isn't made to handle "that kind of load", and insist that you should splice into the big pink wire. However, some on on here did an amp reading on the HEI wire and said it isn't much at all. (15 amps maybe?) Either way you go, you'll be set. |
08-10-2003, 02:02 PM | #3 |
PROJECT 7DEUCE
Mine is hooked up to a green and yellow wire that run's across the top firewll guttere it was hooked up that way when I bought the blazer. I s that the correct way or should I change it?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-10-2003, 02:36 PM | #4 | |
Glowing since 1978
Why not take the firewall connector apart, remove the existing resistance wire and using a type 56 connector and the 12 GA wire from the HEI put it right back into the original slot. This is by far the cleanest setup and the wire on the inside of the firewall connector is 12 GA.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper Last edited by ddsmith; 08-10-2003 at 03:06 PM. |
08-10-2003, 02:54 PM | #5 |
LIKE HE SAID thats what i did , why have loose dangiling extra wires make it look factory
08-11-2003, 02:09 AM | #6 |
Out of the carpool lane.
I made it look factory as well. You can get the connectors at NAPA.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
08-11-2003, 08:07 AM | #7 |
Old Skool Club
www.wiringharness.com
I had to have a new harness for my truck (fried some wires, etc.) and M&H Fabricators (aka wiringharness.com) make harnesses with original colors, connectors and appearance. If you are running an HEI, like me, they'll modify the harness to fit the HEI, making it look factory. It has the large pink wire available for an electric choke, or whatever. Just a suggestion. If your harness is good, modify what you have. If not, here's an alternative.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-11-2003, 05:12 PM | #8 |
PROJECT 7DEUCE
Is this the pink wire everyone is talking about???
08-11-2003, 05:32 PM | #9 |
The one I am talking about plugs into the back of the ignition switch and then into the main harness. I have no idea where it goes to, but if you were to do the upside down under dash boogie, you'll see it going to the ignition switch.
08-11-2003, 07:12 PM | #10 |
Glowing since 1978
That 12 GA pink wire Longhornmail is talking about is the feed to the resistance wire and it goes to the fuse box and the ignition switch.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
08-14-2003, 01:35 PM | #11 |
The post about the fuse box not being able to handle the extra load is actually very accurate. The AMPREGE usage of HEI's is low, but the VOLTAGE demands are kinda high. Going through the fuse box is not goint to overload your fuse box, it will kinda dampen performance of the HEI, as the voltage going into the HEI from the fusebox will be a little lower than a more direct routing. The voltage drop won't be much, but every fraction of a volt the HEI gets, it uses to create a hotter, better spark. If you are not racing the truck, and you never have cold starting problems, going through the fuse box is ok, you'll probably never notice any difference. However, if you have a lot of high ele. demand accessories, or add some in the future, you may want to re-think all of the wiring on the fusebox (I did). hope I've helped
1970 long fleet, 355 4 speed, primer, walnut goodies |
08-14-2003, 03:36 PM | #12 |
Thanks for clearing that one up Shadetree...When i first came to the board some one was asking about HEI wireing and I was flamed for saying the words 'propper way" and 'splice" in the same sentence.
08-14-2003, 03:48 PM | #13 |
EZEKIEL 25:17
Are all fabric covered wires resistance wires?
68 CHEVELLE(HORSESHOE) 69 LONGHORN 396 70 NOVA 454(FOR SALE) 71 SWB 307 71 EL CAMINO 383 72 GMC JIMMY 350 87 BLAZER 350 WIW? http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists. The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers... |
08-14-2003, 03:57 PM | #14 |
Glowing since 1978
Shadetree,
That brings up an interesting subject. I don't want to hijack this post but this is relavent to the subject. This same problem arises from one wire alternators if I'm not mistaken. The one wire alternator senses voltage coming out of the alternator versus the normal setup sensing downstream in the system voltage. If large loads are placed on the one wire system it doesn't compensate as well to maintain 12V way down the line. I take it from your comment on the fuse box being inadequate for hi demand usage that you also believe that one wire alternators are also inadequate for the task at hand.
08-14-2003, 04:03 PM | #15 | |
Glowing since 1978
08-14-2003, 08:53 PM | #16 |
Glowing since 1978
I must be getting old. The correct NAPA part number for the TYPE 56 connectors is 725145 and 725147.
08-15-2003, 02:49 AM | #17 |
ddsmith, I don't like one wire alternators for other reasons, but, thanks, cause now I have one MORE reason not to like em. This post is getting interesting, and, yeah, response is a good issue to consider. But, all these issues are dead, IF the truck is not raced, and/or not being pushed to the limit in other eareas (a super-dee-duper sound system is a good example of pushing these electrical devices to their limits). After designing and installing MY super-dee-duper sound system, I re-did my entire electrical system (and, yeah, I race my truck occasionally). A one wire alternator only LOOKS cool, a much more practacle choice would be a 100 amp regularly wired alternator IMHO
08-15-2003, 03:20 AM | #18 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
One wire alt's put out 14.2 volts at the alt.only.
If demand increases in the system(A/C,high beams,heater on high) the one wire alt's will only maintain the 14.2 at the alt. With all those accessories on the available voltage will drop and the one wire will not compensate for the increased load. A 3 wire,or orig.GM alt., will measure the load on the system and will pump out more juice to compensate for the increased load in the system. GM called it remote sensing. That's the blue wire in terminal # 2 on the alt. ddsmith,the A/C wire is a dark green wire and is only COVERED with a with a protective fabric.The wire itself is a reg. 14 gauge wire. I wired my HEI directly from the PINK IGN. wire at the ign. switch. This switch receives full battery power.I spliced into the large Pink wire and ran that wire through the firewall directly to the HEI. wireing can REALLY suck!:p
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 08-15-2003 at 03:23 AM. |
08-15-2003, 04:35 AM | #19 | |
Glowing since 1978
BobbyK,
Thanks for the clarification on the one wire. It is like I thought but you said it nice and clear. Take a look at this below and correct me if I'm wrong. Quote:
Anyone needing more information/clarification just ask.
08-15-2003, 04:44 AM | #20 |
I should have clarified what I did.
I have removed the resistance wire all together.Actually I have removed that whole circuit that goes through the bulkhead connector.The circuit that normally has the resistance wire in it and would feed the HEI. I'm useing that circuit now to power a 3 wire o2 sensor for my TPI. I"ll actually will be attaching that Pink bulkhead wire to a terminal block as a IGN. on power source for the engine bay. Who know what I'll be adding to this truck in the future. :p
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
08-15-2003, 11:43 AM | #21 |
EZEKIEL 25:17
ddsmith...thanks why I ask was Jewlz has her HEI hooked up by the ing to batt on the HEI and it is a fabric wire. It had me worried at fine69,s but it should be ok.
We all hope! JEFF
68 CHEVELLE(HORSESHOE) 69 LONGHORN 396 70 NOVA 454(FOR SALE) 71 SWB 307 71 EL CAMINO 383 72 GMC JIMMY 350 87 BLAZER 350 WIW? http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists. The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers... Last edited by LonghornJeff69; 08-15-2003 at 11:45 AM. |
08-15-2003, 06:01 PM | #22 | |
Glowing since 1978
LonghornJeff69, you said
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper Last edited by ddsmith; 08-15-2003 at 06:13 PM. |
08-15-2003, 07:03 PM | #23 |
EZEKIEL 25:17
The fabric wire is a new wire installed at fine69s when she
switched to HEI. it runs from the fuzebox to the HEI.
08-15-2003, 07:28 PM | #24 |
Glowing since 1978
I got it now and I understand why you ask. It sounds like her setup is fine. It should keep her going strong. Did she have a spare module with her? It never goes bad when your at home and the parts stores are open.
