09-02-2014, 08:31 AM | #1 |
Converting I6 250ci with 3 on the tree to 350ci small block with 350 autobox...
.... Hi folks I apologise in advance if any of these are dumb questions but hey i'm gona ask em anyway!
I currently have a '66 SWB step side that has a 250 Hi Torque inline 6 motor and 3 on the tree manual gearbox. I'm currently contemplating converting it to a 350ci small block with 350 auto box........ IF I was to go this route, other than the engine (and ancillaries, exhaust, etc) and gearbox, what else would I probably need to change? Would I need a new prop? I'm assuming i'd need a new column shifter set up as well? I've been told the engine mounts should be the same so no change there. Would I need any additional mounts, crossmembers etc. for this 350/350 combo? Any advice, information, help, pointers to other threads etc. on this would be greatly appreciated so I can guage the amount of work involved and the probable costs involved. Thanks in advance. __________________
My old truck: '66 Shortbed Stepside - Ex USAF - Shiny and new on the inside & underside, original patina on the outside. - http://67-72chevytrucks.com/vboard/s...d.php?t=487701 Tattooed pinstriper and graphic designer with an awesome award winning beard! Check me out at http://www.vontash.co.uk |
09-02-2014, 08:37 AM | #2 |
Re: Converting I6 250ci with 3 on the tree to 350ci small block with 350 autobox...
You will need to get a tranny cross member And most folks cut out the old gross member for the bell housing mount. A V8 fan(prop) and shroud will be needed. It is a pretty popular swap. A trans cooler will also be needed. I used the Lokar shifter on mine when I went from 4 speed to auto and really like it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-02-2014, 10:31 AM | #3 |
Post Whore
Bigger radiator as well. Throttle linkage will be different. And your motor mounts won't be in the exact same location on the frame.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
