Old 09-02-2014, 06:49 PM   #1
jordanblea
np205 cross member
Hello all, just recently swapped a t221 tcase for np205 (69 k10), we were able to make the t221 cross member work for now but the cross member is in the way of the front drive line. We can modify the cross member but it might take more cutting than I want to take from it. I have been told 70-77 and 84+ year cross members will work for this np205. I have had a hard time locating one but came across a 83 cross member at the wrecker. Will this work with slight mods or what's the deal there if anyone knows. We can cut and drill the holes if needed, just would love to be able to use the 83 if it'll work. Thanks for any insight and input.
It had to be done.
jordanblea is offline   Reply With Quote
Old 09-02-2014, 07:04 PM   #2
jordanblea
Re: np205 cross member
So I guess I heard wrong on the 84+, just talked with him and he said 84 and older, can anyone confirm this? Thank you.
It had to be done.
Old 09-02-2014, 07:56 PM   #3
BigRed76
BigRed76's Avatar
Well I can speak from experience that the '73-up 205 crossmembers are different than the '72-down 205 crossmembers. Whether or not they interchange I can't say, but physically they are different.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-02-2014, 08:01 PM   #4
jordanblea
Ok, it's a 70-77 np205 according to the code stamped on it C-99404, so for those years they should be the same I imagine, that crosses into different generations. Hell I'm gonna pick it up tomorrow and see how it goes. Thanks guys.
It had to be done.
Old 09-02-2014, 08:05 PM   #5
BigRed76
BigRed76's Avatar
Yes the transfer cases are the same, and the mounts are the same, but with the body change in '73 came a different crossmember as well.
Zach
Old 09-02-2014, 08:11 PM   #6
jordanblea
[QUOTE=BigRed76;6827796]Yes the transfer cases are the same, and the mounts are the same, but with the body change in '73 came a different crossmember as well.[/QU
Hopefully it'll work with slight mods then. Not afraid to notch and drill a hole or 2 but don't want to take out too much if we can avoid it.
It had to be done.
Old 09-02-2014, 08:13 PM   #7
BigRed76
BigRed76's Avatar
So after google searching some crossmembers I see that most of the '73-up crossmembers are very similar to the '72-down crossmembers. So the only potential issue would be the frame width. The NP205 crossmember I had on my '76 bolted to the bottom of the frame but also curved up along the left side of the frame and bolted on the left side.
Zach
Old 09-02-2014, 08:15 PM   #8
jordanblea
Good to hear, we will make it work! Just need to figure out the torque mount from there. Can't wait to have 4x4 again, it's about time for the aspens to change colors in the Colorado high country want to take the 69 up there in a couple of weeks. Thanks for your help!!
It had to be done.
Old 09-02-2014, 08:15 PM   #9
BigRed76
BigRed76's Avatar
So the top picture is the '72-down np205 crossmember, and in the 2nd picture, the top crossmember is what I've seen on '73-up trucks.
Zach
Old 09-02-2014, 08:19 PM   #10
BigRed76
BigRed76's Avatar
I've seen on here that multiple guys don't run the torque mount on the np205's because it doesn't allow the drivetrain the flex very much and potentially causes things to break, but I don't know if there's any truth behind that. And I do know that the '73-up np205's don't use a torque mount, so maybe a reason for that.
Zach
Old 09-02-2014, 08:23 PM   #11
jordanblea
The 2nd pic the top cross member should work, the bottom is the "W" style that I don't think will work.
It had to be done.
Old 09-02-2014, 08:28 PM   #12
jordanblea
As long as it's not solid mounted and you have flex (rubber bushings) in the mount should be good, it needs to flex with the motor and transmission, other wise the adapter is the weak spot and is know to fail. Solid mount is good if your motor and transmission is all solid mounted. The flex then would come from the whole truck rotating. Still not 100% on if I'm gonn have one there or not I guess. If it's not torque mounted then it just sit's on the cross member I guess. There are theories both ways I guess.
It had to be done.
Old 09-02-2014, 08:30 PM   #13
jordanblea
I said "I guess" a lot on that last one lol
It had to be done.
Old 09-02-2014, 10:13 PM   #14
jordanblea
So now I just learned that 1981+ 1/2 and 3/4 ton trucks came with the np208 (the "w" cross member), and that cross member will not work. If it's off of a 1 ton truck (came with the np205) will that work?!?! Super frustrated by this whole thing been looking for almost 2 weeks and cannot come up with the right cross member. I'll know more tomorrow I guess.
It had to be done.
Old 09-03-2014, 01:02 AM   #15
'68OrangeSunshine
'68OrangeSunshine's Avatar
On my '71 GMC Jimmy [V8 350/SM465/NP205] I have 2 X-Mbrs, the forward one supports the tranny and engine, and I guess the back one supports thr Xfer case and the rear of the skid plate. I currently have the skid plate off and also the back Xmbr. I don't need it for any radical 'wheeling. But intend to put it all back together one day.
The fuel tank is also armored with a skid plate and about 48 bolts. My gas gauge is INOP. I can't get to dropping that piece yet either, so I just keep a log on my mileages and gas intake and figure to fill it up every 200 miles.
'68OrangeSunshine is online now   Reply With Quote
Old 09-03-2014, 03:29 PM   #16
CUSTOM/10
CUSTOM/10's Avatar
Watch the parts board on this site, or pay $25 and join so you can post a WTB add. The correct crossmember would be from a 70-72, auto or standard, with a NP205, truck or blazer. I had a few of them but sold them all.
I didn't see what yr your truck is but this info is for 67-72 chevys !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 09-03-2014, 04:17 PM   #17
CUSTOM/10
CUSTOM/10's Avatar
Where are you having the interference ?
By chance is your front output yoke a square 4-bolt flange type ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
