09-02-2014, 10:24 PM | #1 |
Upgrading brakes on 1950 1 ton 3800.
My brakes are the next job on my project list on my '50 3800 single wheel 1 ton. My idea is to change over the front to disc and keep the stock rear drums. I don't want to spend a fortune, but I do want to do it right. Do I buy the caliper bracket and piece the front brakes together from picknpull or do I buy a kit that has everything I need, including master cylinder and brake booster. What's everyone's thoughts on either those options or are there other options I'm missing. Or should I keep everything stock and just add a brake booster? I'm fairly new to a lot of this and I bought this truck as a novice mechanic- meaning I need to keep it somewhat simple.
09-02-2014, 11:05 PM | #2 |
Re: Upgrading brakes on 1950 1 ton 3800.
You won't get discs on the front of a 1 ton, unless you put a 1/2 ton axle in it, which I'm not entirely sure will fit. Or put in a Camaro, Jaguar, Mustang front end on it. Which might not fit either.
There is a guy on here building a kit that might work, but from the work he's done on it, it looks a little pricey. If he even builds more than one. Last edited by Hogger54; 09-02-2014 at 11:13 PM. |
09-02-2014, 11:39 PM | #3 |
Hollister Road Co.
We sell a 3600 and 3800 disc kit.
http://www.hollisterroad.com/proddet...keconversion38 install documentation http://www.thehollisterroadcompany.c...converion.html We provide the brackets, machined wheel spacers to fit the rotors, and the new mounting hardware and stud spacers, install instructions and a complete list of brake parts you need. You can source new or used Chevy 2500HD brakes and parts. It retains the stock GM axle and hub. You need to replace the stock wheel studs and shorten them a 1/4", that's all the machining you do. You do need a dial indicator to check the run-out of the disc and hub package so you don't get a vibration. |
09-02-2014, 11:59 PM | #4 | |
Hollister Road Co.
I'd be a bit leery of using a booster on stock wheel cylinders. You are increasing the line pressure by 100% by adding a booster. You would have to replace every line and hose and cylinder to be safe and then you over the cost of a disc swap By adding disc brakes you need approximately 1200 psi line pressure to stop a 1 ton loaded. The stock drum master system would put out about 600 psi. To get proper line pressures you need a 1.125" to 1.47" (37mm) diameter master and a dual 8" booster. So its a leave it stock or go all in kind of deal. You can get after market disc kits for the HO 72 rear end or do a 14 bolt swap. Disc on a 1 ton is not a cheap deal to do because the parts are costly even rebuilt. |
09-03-2014, 12:14 AM | #5 |
Oh wow. My bad. I didn't think you had worked all the bugs out yet.
The kit looks good. |
09-03-2014, 12:32 AM | #6 | |
Hollister Road Co.
We don't swap the bearings in this conversion because there are no direct swap bearings available and some have reported failures with the close to fitting bearings. Couple that with ball bearings are still a good bearing for these trucks so I saw no reason to change the. |
09-03-2014, 10:49 AM | #7 | |
that looks like a good kit you put together dwcsr.
60 some year old brakes should be totally replaced i do question the use of the aluminum spacer pressed into the cast disc i don't see that coming out of the disc in a couple years without cutting the disc though i don't see a way around it either unless you used the 1/2 ton axle
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-03-2014, 01:52 PM | #8 |
All the wheel cylinders have been replaced by the previous owner, but they didn't run new brake lines. The old lines are trash anyway so they will be replaced. It still be ill advised to put a booster on my stock drums?
09-03-2014, 03:42 PM | #9 | |
09-03-2014, 04:03 PM | #10 | |
Hollister Road Co.
09-03-2014, 04:30 PM | #11 | |
Hollister Road Co.
I find it amusing that all the whining I hear about no one makes anything in the US anymore and when they invest time and money to make a parts here everyone wants that cheap China price. I don't ever want to be faced with someone who purchased my parts and loaded up their kids and 4 wheeler and crashed because it wouldn't stop all because I cheaped it out and used half ton China joe parts and sold it as 1 ton brake upgrade. We don't ever do cheap, its done to the best of our ability or we don't sell it. |
09-03-2014, 05:16 PM | #12 |
That's a great looking setup Dave.
Neverdone50 you would have to take into consideration that this is very close to a one off setup and Dave isn't getting some big price break on machine work by having them knock out a thousand or ten thousand at a time. I'd hate to think what it would cost locally to have a pair of those spacers made in a job shop machine shop at shop prices here if you walked in the door with only a set of detailed drawings. One thing I really like is that they sell you the pieces you would need to have made to do the conversion and you buy the rest of it locally and for some of us that may work into a nice break on the prices of the parts if we can get a deal or if we can get a deal on some of the pieces used. A guy might even get the rear axle out of the donor rig he got the front brake pieces from and end up with a matching brake system front and back and much newer rear end in the process.
09-03-2014, 05:40 PM | #13 | |
Hollister Road Co.
Thanks we aimed at making it a bolt on and do the hard work for you and you use what you can source for bolt on parts. We just finished a swap that used our front brakes and a 14 bolt with discs. Your right about job shops. The first set of brackets cost me $180 for two brackets made here on a short run. The stud spacers I make on a lathe from 304 bar stock. The inside is threaded to 14mm x1.5 and the outside is turned so its just fits the rotor. These alone if made at a job shop would be $4 each x 16 = $64. The aluminum spacers i buy at just about retail because again its by the pair or 2- 3 sets at a time then we then re machine them. In the end you have 13" disc brakes with dual piston calipers. Half tons are 11 - 11.5 singles. |
09-03-2014, 06:03 PM | #14 | |
09-03-2014, 06:14 PM | #15 | |
Hollister Road Co.
09-03-2014, 06:21 PM | #16 |
I've been a round or two at having parts machined in a one off basis when I worked in a large food processing plant in the late 90's and we had several machines that had come from Germany that were very low production machines as to how many were made and sold world wide. That was before it was at all common to send an Email to inquire about parts or service and the company we got the machines from had no one in house that spoke English.
09-04-2014, 12:10 PM | #17 |
This is great that a disc brake kit is finally available for the 3/4 ton and larger trucks. I wish I would have waited longer to buy the '53 axle with more modern brakes... But I guess that's how these things go. I'm very interested in this kit. Especially since it's made in USA!!! What wheels can you use with the disc brakes kit? Will the stock wheels fit? I'd like to use wheels that are stock, or stock looking and want to run the 3/4 ton hubcaps. Do the wheels stick out more?
09-04-2014, 06:48 PM | #18 | |
Hollister Road Co.
They actually look better out an inch. The stock width has the wheels tucked in a bit. This brings them closer to the fender but still inside of it We tried very had to make this kit appear to be an option you could have gotten or at minimum look unassuming. You can also with a little modification use the original backing plates as a dust shield. With the stock 17" wheels and the backing plate you don't really see the disc at first and you can't see it through the wheel We had Stockton Wheel make some wheels that use the stock 17' centers and tubeless ousters on an 17 x 8" wide rims and it hides everything. If I had to do it again I'd go with 6 or 7" wide. We wanted to be able to use the clip on hub cap for that era that's the reason for the wheel conversion. |
09-05-2014, 04:36 PM | #19 |
I would really like to see a picture of the truck done. I have bought all my bolt on parts and will get my kit from you in the future, hopefully by years end. So, next run you make please hold one for me. I have no plans of changing from the 1 ton maybe a single wheel 1 ton instead of a dually. Depends if I can source a good bed.
Thanks for all the hard work Dave and I am glad all parts are made in the USA. |
09-05-2014, 06:45 PM | #20 |
Hollister Road Co.
Here are some of the truck they are on now.
09-13-2014, 07:15 PM | #21 |
Hollister Road Co.
We have this driving now. It stops with about 4-1/2" of pedal left. We tried to lock them up but couldn't. 2500 HD 13" brakes up front and 14 bolt axle w/disc on the rear. 1-1/8" master, dual 7"booster but you should use a 8" dual.
https://www.youtube.com/watch?v=jF2R...ature=youtu.be |
