Old 09-02-2014, 11:09 PM   #1
JerrittB08
Weird sound turning truck off
I have a 72 c10 350v8. Sometimes when I turn it of the engine will make a shhhhhshhshh sound. it dosent do it every time, maybe every 7th or 8th turn off. Does anyone have any ideas what this is?
JerrittB08 is offline   Reply With Quote
Old 09-02-2014, 11:14 PM   #2
Lee H
Lee H's Avatar
Re: Weird sound turning truck off
Run on maybe?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-02-2014, 11:36 PM   #3
no1udknow
no1udknow's Avatar
Sounds like vacuum bleeding off. Could be a leak in the diaphragm for the brakes if you have a booster. Or maybe in the HVAC system
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-02-2014, 11:47 PM   #4
Crazyduck
A/c compressor will do it too, If you have it.
Crazyduck is offline   Reply With Quote
Old 09-03-2014, 12:07 AM   #5
zeldman
zeldman's Avatar
Hard to tell without hearing the noise. Could be PCV is stuck.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 09-03-2014, 12:38 AM   #6
JerrittB08
It not a hose or anything, it sounds like the whole engine turning over. What do you mean by a run on
Old 09-03-2014, 07:25 AM   #7
no1udknow
no1udknow's Avatar
The only other suggestions I have is a vakve that may be too tight or not seating properly letting compression leak back in to the intake or a loose spark plug, but thats only if your sure it is coming from the engine. You could check both by pulling power from the coil/hei and bumping the engine a little at a time and see if you start to hear it.
Built not bought!
Old 09-03-2014, 07:32 AM   #8
dfrank
dfrank's Avatar
Too much timing can sometimes cause a run on. Double check your timing. It could be as simple of a fix of just turning the distributor a little. Good luck.
dfrank is offline   Reply With Quote
Old 09-03-2014, 09:23 AM   #9
luvbowties
luvbowties's Avatar
Smile Re: Weird sound turning truck off
Having idle speed set too high can cause it. If it keeps on after all our suggestions & it worries you, try cutting it off while still in gear--assuming it is an automatic.
Luck to you,
Sam
luvbowties is offline   Reply With Quote
