Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-03-2014, 10:25 AM   #1
1963c-10
1963c-10's Avatar
1961-63 c20 standard hub caps x2
picked these up a year or so back for $40 for the pair. Been painted several times, will clean up nice, but definitely not show quality. Minor dents, nothing bad....has plenty of surface rust on back....but no holes. See pics....if additional pics needed, please let me know. Paint looks horrible, but the caps are actually pretty nice.
2 caps 1961-63 c20
Will do $20 a piece if only one wanted or $40 for the pair plus shipping
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-11-2014, 11:30 AM   #2
1963c-10
1963c-10's Avatar
Re: 1961-63 c20 standard hub caps x2
Take $40 shipped if any interest....
Old 09-25-2014, 01:34 PM   #3
1963c-10
1963c-10's Avatar
Open to offers......
Old 09-25-2014, 02:54 PM   #4
oem4me
The poor paint does make them appear pretty rough. Are either dent free? If so, I'm interested.
Old 09-26-2014, 08:12 AM   #5
1963c-10
1963c-10's Avatar
Let me look them over when I get home. I know the paint definitely makes them look worse than they are.
Old 09-26-2014, 09:16 AM   #6
GMCNUT
GMCNUT's Avatar
These are not C-20 caps - commonly mistaken for such though. There are two types of steel rings pressed in the backside of caps - one skinny set (like these) used for clip type 16" rims and another wider ring used for 3/4 ton and 1 tons.
If I have it backwards, anyone can correct me, but if my memory serves me right, the ones on my 64 3/4 ton are the wide version
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 09-26-2014, 11:23 AM   #7
1963c-10
1963c-10's Avatar
I'll get some measurements off the back. Didn't even consider the 16" rims into the equation. I'll get better pics and measurements tonight.
I really need to get measurements after rereading this post
Link: http://67-72chevytrucks.com/vboard/s...=501034&page=3 post 67.......
Old 09-26-2014, 12:39 PM   #8
GMCNUT
GMCNUT's Avatar
I may have it backwards - wish I knew who to ask for sure - I know 3/4 and 1 ton uses one type and 16" clip type wheels came with the other, so I may have it right backwards - could be skinny is 3/4 and 1 ton and wider rings are 16" clip type .....maybe another member will chime in and clarify if I am right or not.
Old 09-26-2014, 01:37 PM   #9
oem4me
All 3/4 ton, eight lug wheels used the skinny ring caps (larger opening). 1/2 ton, 15" six lug wheels used the wide ring caps (smaller opening). What I cannot say, is which cap the 16" six lug wheels or 17.5" six lug wheels used.
I think it may be as simple as: all eight lug= skinny, all six lug= wide
Of course, all of the above info applies to clip type wheels, not the bump type, for which the caps had no rings.
Old 09-26-2014, 03:20 PM   #10
1963c-10
1963c-10's Avatar
I'll get some measurements tonight and maybe it'll help figure out their application.
These are 3/4 - 1 ton caps based off the inner ring size.
Old 09-26-2014, 07:03 PM   #11
GMCNUT
GMCNUT's Avatar
There you go - I knew someone would know for sure. I have a 3/4 ton truck w/ caps on it, but couldn't remember without going over there and popping one off - I guess I had it backwards - sorry for the false alarm
