Quick offset question on some wheels
I won some amazon credit from work and wanted to use it to purchase some wheels for my 68 c10 2wd and only wheels i found on there that i like are the Torq Thrust IIs. Only size available in 20 inch wheels are 20x8 5x127 0mm for the front and 20x10 6mm for the rear. Will these tuck if i decided to bag my truck later?
Re: Quick offset question on some wheels
Sorry I know the front will tuck I meant the rear wheels
I would like to know too!
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
#4 | |
You can make literally anything tuck but to do it you need to know the dimension from the inner edge of the wheelhouse to the mating surface of the wheel, the distance from the mating surface of the wheel to the inner edge of the outer wheelhouse and the distance from the frame to the inner edge of the outer wheelhouse. Pics are 14 inch wide rims with 17 inch section with tires on a 67 stepside. They have 1.5 inches clearance on each side. |
Sorry fleetside bed and have drums now but I'm converting to disc brakes all the way around or may decide to just do disc brakes in the front and keep the drums in the rear.
