Front end swap
I know this has probably been discussed on here and if someone could point me to the appropriate thread I would appreciate it. I'm entertaining the thought of putting 73-74 sheet metal on the front of my 81 and was wonder what problems I will encounter or if it is even possible. Thanks
Re: Front end swap
Should be a direct bolt on with some minor tweaking the harder swap is going 73-79 to 81 an up the cabs have different holes for the hood to bolt up that you've got to workout, Hope that helps you!
Re: Front end swap
Thanks, makes me more confident to dive into this project
Re: Front end swap
You'll have to switch out the wipers to the older year
Re: Front end swap
If you need pics just let me know.
Re: Front end swap
Pics would be very helpful. What is different about the doors, when you look up replacement doors they go from 73-77 and then 78-87? Does that have to do with brackets that mount the interior components?
Re: Front end swap
Doors are 73-76 and 77 up. It has to do with the interior panel mounting.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
Active Member
![]() Join Date: Oct 2012
Re: Front end swap
I would also like to do a swap of the older sheet metal to an 81 cab/frame.. anyone know what all is involved ?can this be done without a lot of cutting?
