Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-03-2014, 07:46 PM   #1
pvienneau
pvienneau's Avatar
back yard media blaster recommendation?
all, I got a gift cert in the form of a visa card from work and am looking to buy a pressure media blaster. My budget is $250. What do you all recommend?
Pat
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 09-05-2014, 02:43 PM   #2
KMC3420
KMC3420's Avatar
Re: back yard media blaster recommendation?
I have an Eastwood, 100 lb. media blaster, works very well for me. I run Black Diamond blast media through it, 80 grit that I buy from Tractor Supply for $7/50 lb bag. I also have an 80 gallon 5 horse compressor. Most blasters work great, the only limitation is how big your air compressor is.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 09-05-2014, 05:47 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
x2. I bought a harbor freight one, and it sorta worked but it was horridly inneficcient on air...making a weak compressor WAY worse.
If you think you'll use it alot, then go ahead...but I've run into a handful of problems with blasting, and just choose to use a DIY blaster that rents by the minute near me.
Consider
A) the flow rate of the gun, and how much air it requires to use on a reasonable duty cycle.
B)will you be using/building a cabinet for it? this affects the type of material used, and your ability to recycle blasting media.
C)Blasting Media. As mentioned above, wether or not you'll use a cabinet makes a difference. As does what you plan on blasting. Walnut vs Soda vs Iron vs Alum oxide etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
