Old 09-03-2014, 09:04 PM   #1
kitsbeach
kitsbeach's Avatar
1967 rear axle width and backspace question
I'm about to do the 5-lug conversion on my 67 Fleet and wondering if people have an easier time getting the right backspace with the later axles (which I believe are roughly 1 and 1/2' wider or so).
I believe the switch to the wider axle happened half way through 1970.
I'd prefer to stay with most 1967 stuff and I like everything pretty tucked in. I'm planning on running 15x8 steelies on the rear but may go for a taller wheel/low profile tire later for the better handling.
I'd like to have the easiest wheel selection as a lot of rims come with a standard backspace.
My truck has an open (non-posi) 12 bolt with 4.11s. If I keep this rear end I will buy the conversion axles and drums now for about a $300 investment. Then later when I do a V8/LS swap I'll spring for something like an Eaton positraction and the right gearing.
The other choice is to swap in the later 5-lug housing now, but this one works and has new brakes and lines.
Here is a picture from underneath of the wheel in the rear fender well now (fairly tight to frame). I don't know the backspace on the old mags that are on the truck now.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
