Old 09-03-2014, 10:50 PM   #1
Rat65
How can i raise the front end of my 65 gmc 2wd
I know its a noob question but im new to these trucks :pName:  image.jpg
This is the stance im trying to achieve.
Any feedback is welcomed!
Rat65 is offline   Reply With Quote
Old 09-03-2014, 11:09 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: How can i raise the front end of my 65 gmc 2wd
It's much easier to get one of the Ford's up that high because they came with straight axles during this period (and earlier). On our trucks the first step is putting new original springs in. If that isn't enough new/custom longer than stock springs will bring it up further. There is a practical limit before the front end can no longer be brought into alignment.
Back in the 60' & 70's when the nose high style was popular, there were spacers for the upper ball joints that allowed more front end travel. There are still both the spacer type, and the "C" style listed on Ebay for many popular models. If I remember correctly, only the "C" style allowed alignment adjustment. It would take some research to see if these would fit the upper ball joints in the 65 GMC truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-03-2014, 11:15 PM   #3
hopped up
hopped up's Avatar
It's easy! Cut off the frontend and install a straight axle from an econoline
hopped up is offline   Reply With Quote
Old 09-03-2014, 11:39 PM   #4
Rat65
Thanks for the input markeb01!
Im digging your build thread
Nice truck!!
Old 09-04-2014, 01:43 AM   #5
LVPhotos
LVPhotos's Avatar
Hydraulics like this, or bags. Just put junk in bed like your picture.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-04-2014, 06:47 AM   #6
PGSigns
PGSigns's Avatar
A set of stock front springs and a 5" drop in the back would just about get you there. A set of Halibrand wheels and you would be good to go.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-04-2014, 08:50 AM   #7
Improbcat
Improbcat's Avatar
If you want it to look just like that truck you'll need to remove the stock suspension and weld on a straight axle. Speedway sells kits in various widths to match the stock axle width.
http://www.speedwaymotors.com/Search...aight+axle+kit
By the way, that look of the big slicks out back, the front high in the air on a straight axle with a big motor is called a "gasser."
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
