Old 09-04-2014, 04:48 PM   #1
SourTooth307
SourTooth307's Avatar
Driveshaft Play, "Clunks" Into Drive and Reverse
Not sure how to tackle this one. Could it be U-Joints? How do I properly diagnose this one? I can feel the play in the driveshaft if I pop the truck into neutral, crawl under it, and twist the driveshaft by hand.
My Wheels:
1984 Chevrolet K/10 Scottsdale 350cid *SOLD*
1989 Cadillac Fleetwood Brougham d'Elegance 307cid
2015 Chevrolet Silverado 1500 LT Texas Edition 5.3L 4x4
SourTooth307 is offline   Reply With Quote
Old 09-04-2014, 04:54 PM   #2
MountainGoat1966
Re: Driveshaft Play, "Clunks" Into Drive and Reverse
Sounds like U joints to me.
I had play in one of mine, replaced it, and the old one wasn't even dry or worn bad.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 09-04-2014, 05:00 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
have a look at them,try to grease em, are they the originals?
the gap should be even all around it(mine had uneven space on lower left)
but grab it,if it moves/jiggles/noisey it's time.
i call it a "ping" seems to resonate up the shaft.
could mark it's position,remove and inspect,but watch sliding the end cap off...
loose a needle bearing and gona have to do them.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-05-2014, 08:10 AM   #4
Keith Seymore
Keith Seymore's Avatar
When you can move it by hand does the rear axle pinion flange move too? (or just the u joint)?.
Just trying to determine if it is excessive lash in the rear axle.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-05-2014, 10:25 AM   #5
SourTooth307
K
I think so, yeah.
My Wheels:
Old 09-06-2014, 12:52 AM   #6
savatreatabvr
savatreatabvr's Avatar
Crawl under the truck and grab the rear pinion flange, aka (yoke) it's what the rear u-joint bolts to and push up and down! If there's play it's time to replace some pinion bearings! I recently had the same thing happen to the point where I almost dropped the drives haft doing 70 mph down the freeway! Remember, yoke movement up and down if bad, bad bad!
savatreatabvr is offline   Reply With Quote
Old 09-26-2014, 04:22 PM   #7
SourTooth307
So it's been a while but I finally had an opportunity to crawl under the truck and twist the driveshaft around. Turns out the play is coming from the yoke and not just the shaft. I didn't notice any up and down play, but it does twist. So on to these pinion bearings, what's involved in replacing them?
My Wheels:
Old 09-29-2014, 08:34 PM   #8
c10454
Check the hanger or carrier bearing. The rubber isloator get old and worn and transmits a lot of noise when shifting into R or D. After changing mine its much softer and quieter going into gear.
c10454 is offline   Reply With Quote
Old 09-30-2014, 01:27 AM   #9
SourTooth307
How is that done?
My Wheels:
Old 10-01-2014, 06:52 PM   #10
c10454
If the rubber looks dry and cracked, if the rubber looks to be pushing out. If you can move the driveshaft by hand at the hanger bearing, the worn rubber will allow it to move. If the u-joints are worn and need to be replaced chances are the hanger bearing does as well.
Old 10-01-2014, 07:52 PM   #11
farmall
farmall's Avatar
Transfer case chain.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
