09-04-2014, 06:58 PM | #1 |
Air Conditioning Compressor clutch not engaging...
So, I just went and bought a recharge/retrofit kit for my A/C, and it now has a full charge and no leaks, but I have discovered that my A/C compressor clutch isn't engaging when the lever is turned to "max" or any other settings, what are the potential causes? It was working maybe 3 months ago, but I am suspicious about a possible blown fuse? There are no fuse block diagrams that look like mine, and half the lettering on it is either work off or unreadable/not understandable... Hopefully I can find an answer... next after this, heater!
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End |
09-04-2014, 07:02 PM | #2 |
Re: Air Conditioning Compressor clutch not engaging...
I do remember lubricating it at one point because it was making a horrendous grinding noise, but it still worked after that point, and only just today did I notice it wasn't rotating...
09-04-2014, 07:39 PM | #3 | |
How did you manage to get a full charge in there if the compressor wasn't engaging?
Grinding isn't good. First comes grinding, then the compressor locks up.
09-04-2014, 07:43 PM | #4 |
It's not the "locking up," it doesn't lock up... the clutch isn't engaging with the compressor pulley. And on the topic of the pressure, it pressurized according to the gauge, I am not sure exactly how much is or isn't in there, but I just found a completely melted plug sitting loosely behind the compressor body, with a green and black-ish wire in it. Is that the electrical component required to engage/disengage the clutch?
09-04-2014, 07:45 PM | #5 | |
Yes, one green wire one black wire.
09-04-2014, 07:46 PM | #6 |
So that's the only issue... I will get that sorted, and everything should work! Thanks for the tips, though!
