Old 09-05-2014, 12:19 PM   #1
70c-10
2001 Tahoe, No power to stock radio
I was in the process of packing for a 600 mile roadtrip this weekend. I went to the store. When I got out of the Tahoe, the radio shut off as it normally does when I opened the door.
When I got back into the vehicle after shopping, the radio did not turn on when I turned the key. I pushed the power button and nothing happened and then also noticed the clock (part of the radio) has no power at all.
I checked the fuse and it looks fine (swapped it out just in case). The door chimes, windows, and dome lights all seemed to be functioning correctly.
Any ideas?
6 in a row, makes it go!!!
My Car
'88 SWB Daily Driver
70c-10 is offline   Reply With Quote
Old 09-05-2014, 01:55 PM   #2
70c-10
Re: 2001 Tahoe, No power to stock radio
For the driver's side instrument panel, I checked and replaced (it wasn't blown):
'RDO I' - Audio System, Onstar
under the hood, I checked and replaced (it wasn't blown):
'RADIO' - Audio System, Instrument Cluster, Climate Control System
I also checked
'RDO AMP' - Radio Amplifier
My Car
Old 09-08-2014, 05:19 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
any codes in the BCM ?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-09-2014, 12:19 PM   #4
70c-10
So I got back from my roadtrip last night.
The radio is working intermittently, with no rhyme or reason. Do you think something is wrong with the radio itself or something with wiring?
Do I need a scan tool to check? I don't have one.
My Car
Old 09-11-2014, 12:13 PM   #5
70c-10
This morning I realized that if I press the 'Recall' button, the display lights up for a few seconds and shows the time.
Could this be the delay shutoff causing the problem?
My Car
Old 09-12-2014, 06:45 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
if this was a customer's truck I would use the scan tool to check for BCM codes and make sure communication is working between modules. Then I would check powers and grounds before condemning the radio
