09-05-2014, 05:29 PM | #1 |
What's up with VH Coachworks"???
I see where they were banned from selling on this board awhile back but did they ever get their s**t together?? I assume they are still banned? That sucks cause I really need one of the headlight relay harnesses and I am not smart enough to figure out how to do it myself. The Painless Wiring headlight harness they sell has gotten too expensive for me and I heard the LMC one isn't very good.
Could someone do a build thread on this with actual part numbers and step by step instructions? I prefer not to cut the original harness, I was thinking of a "plug and play" option. Someone who is good with electrical should start building these to fill the void left by VH Coachworks. (Hint hint Vetvette, TX Firefighter). Sorry if I misspelled your board names. |
09-05-2014, 07:40 PM | #2 |
Project Junkie! Fishing Poor!!
Re: What's up with VH Coachworks"???
I have never understood the need to do this conversion. Convert to an internally regulated alternator and run a 90 amp alternator. The lights are extremely bright and don't dim when coming to a stop. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-05-2014, 11:02 PM | #3 | |
I did a conversion on a 240z back in 2000 by just using a relay where the power goes into the passenger compartment and using the stock wire coming from the switch as the on/off for the relay. I had to add another 18 gauge wire to power the switch, but that's all it took if I remember right. It was 14 years ago so I couldn't tell you which switch I used, but I think I might have got it at an auto parts store. |
09-05-2014, 11:08 PM | #4 |
Classic parts sells a kit that works fine, I used it.
http://www.classicparts.com/Headlamp.../#.VAp6kGP76dg
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
09-05-2014, 11:43 PM | #5 |
vive me a day, I can build you a diagram and parts list. Very simple to do.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
09-06-2014, 12:09 AM | #6 |
09-06-2014, 12:12 AM | #7 | |
Are you using stock bulbs, halogen, or something else? |
09-06-2014, 12:19 AM | #8 | |
1970 GMC K2500 aka MaTeR 2007 Chevy Silverado 1500HD Classic |
09-06-2014, 12:24 AM | #9 |
Moderator
Txfirefighter has an excellent write up in FAQ for building your own harness. It is inexpensive and very simple to do. If however you do not want to source your own parts, the LMC harness is plug and play. Simply remove the hideous yellow wire wrap, tuck the wires into your OEM loom cover, and route the harness relays under the battery tray, and it looks 100% stock and hidden. I have had one on my current truck for three years now with zero problems. Upgrade to the relays, swap in some Sylvania Silver Star sealed beam headlights, and enjoy an enormous difference over your stock lighting.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-06-2014, 09:01 AM | #10 | |
09-06-2014, 10:09 AM | #11 |
heres a pic
JJ 71 SWB 360 Th400 4.56 |
09-06-2014, 03:00 PM | #12 |
I upgraded my lights and installed the relays from that diagram and it real easy, works great and lot better brighter lights.
09-06-2014, 05:19 PM | #13 |
Not sure where you herd bad things bout lmc's heavy duty harness but I have over five thousand miles logged with mine and most of it nightime driving. Sure there Chinese but not everything they touch is complete garbage like everyone says.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
09-06-2014, 08:15 PM | #14 |
Halogens
09-06-2014, 08:17 PM | #15 | |
09-07-2014, 08:51 AM | #16 |
I made my own harness after my headlight switch went out. at the time I was running a stock charging system and it really helped.
we routinely do the headlight relay conversion on land rovers because the headlight switches are $125 new and don't last very long if you don't
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
09-07-2014, 10:06 AM | #17 |
Thanks for the info guys and thanks to JJLT1 for the diagram but does anyone have a diagram where the original harness remains uncut?
