Old 09-05-2014, 07:25 PM   #1
SierraMtns
SierraMtns's Avatar
Talking What Year Is My Truck?
Ok so I am not sure where to begin. Here it goes. The truck is "registered" as a 1967. However after starting to work on it I started to notice little things that got me thinkin, is this really a 67?
Last night I went to our local 67-72 parts guy and picked up some 67 door panels but they DON'T fit.
I need your guys help to figure out roughly what year cab and doors I have.
Here are the panels that don't fit. They have a ledge at the top that slide under and then bolt at the bottom.
Here are the doors on the truck.
Here are other pictures inside the cab. I thought I read somewhere that the ashtrays on the 67 are smaller?
Dash.
Under the pedals.
Thanks for the help.
SierraMtns is offline   Reply With Quote
Old 09-05-2014, 07:35 PM   #2
casper71
Re: What Year Is My Truck?
looks to be a 67. your missing the trim that goes across the top of the panel. this secures the top of door panel then bottom bolts in.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 09-05-2014, 07:37 PM   #3
SierraMtns
SierraMtns's Avatar
Oh that makes more sense.
So the cab and doors look to be 67?
Old 09-05-2014, 07:40 PM   #4
71swb4x4
71swb4x4's Avatar
The ignition switch is 67 only, so that cab is a 67. In 68 the ignition switch hole is larger.
All your knobs are 68-72 but those were probably changed by a PO.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-05-2014, 10:44 PM   #5
bowcoffin
Hand break- 67-68. Look at the fenders. Are there side lights? If so it is a 68. If not it is a 67
bowcoffin is offline   Reply With Quote
Old 09-05-2014, 10:49 PM   #6
67chevy1
67chevy1's Avatar
Its a 67 dash the cig. lighter isn't recessed. Casper is right your door needs the lock channel at the top.
67chevy1 is offline   Reply With Quote
Old 09-06-2014, 12:32 AM   #7
SierraMtns
SierraMtns's Avatar
Do you have a picture of the lock channel?
I am surprised my parts guy didn't mention the lock channel at the top.
Old 09-06-2014, 12:41 AM   #8
Nitis
Nitis's Avatar
You use Joe & Marie I think there name is over by orang ale I think? Always on CL
If no I'm interested in your guy I live about 25 minutes from you
Nitis is offline   Reply With Quote
Old 09-06-2014, 07:08 AM   #9
midniteblues
midniteblues's Avatar
your doors are 67 also they have the round holes not the teardrop shaped holes like the later years.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-06-2014, 08:54 AM   #10
sboris
sboris's Avatar
Not the greatest pic, but shows the strip at the top your missing. Held on with 4 screws. The far left hole that holds your door panel seems to be occupied by another bolt. Looks like it should work ..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 09-06-2014, 09:07 AM   #11
Joesjunk
Joesjunk's Avatar
Make sure you get the painted ones (just like in the pic), not the chrome ones, the chrome strips are designed for the thicker vinyl covered fancy door panels
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 09-06-2014, 01:04 PM   #12
SierraMtns
SierraMtns's Avatar
Yeah the PO shaved the door handles. The other bolt is holding the solenoid to pop the door open. I am working on converting it back to reg door handles.
Cool thanks for the info. I will have to look for some painted ones. My parts guy might have some. If not I wonder if LMC carries them?
Old 03-24-2015, 09:27 PM   #13
no1udknow
no1udknow's Avatar
good luck with that, most people who shave the door handles also fill in the indentation behind the handle, you might be better off swapping doors with someone who wants shaved handles.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
