Can a bad carburetor cause engine damage?
hey!
I've known that my carb is bad for a while now, just a bunch of vacuum leaks and thus, a rich mixture, but can this cause engine damage? I just need to know if I have to spend the 600+ on the carb and manifold now, or can it wait for a while without seriously harming the engine? I heard that it can cause issues, and I just need to know, as I'd hate to have to end up replacing the carb and manifold, as well as all the piston rings and seals etc. Cheers guys, '81GMC
1981 ![]() |
Re: Can a bad carburetor cause engine damage?
can a bad heart cause human damage lol
ya it can cause some damage foul up your plugs, valves etc |
I thought so, is this damage permanent? (It's been running like this for who know how long), or can it be cleaned out with a few cycles of engine cleaner additive? I appreciate the advice!
1981 ![]() |
Fuel wash is the problem. Excess fuel can varnish your cylinder walls and your rings and walls get scored.
You need a little oil splash from below to keep the walls in good condition. I thought you were gonna rebuild that carb. |
![]() Join Date: Aug 2014
+1 just rebuild your current carb. What carb is on it now?
Geezer, I found out it isn't worth rebuilding, it has too many vacuum leaks, and frank, it is a Q-Jet. It isn't running too too rich, it is showing minor signs of a rich mixture, and fuel smoke out the pipes at startup and in park when revved, but I'm thinking it won't be a dire emergency, but it it is, I will replace asap.
1981 ![]() |
Some think the Qjet is a great carb. Vacuum leaks have nothing to do with the goodness, or whether a carb is rebuiladable.
If vacuum leaks are a prblem, the engine is running lean. Chances are the carb isn't the primary issu. Find and fix the vacuum leaks. Or, start from square one to diagnose the issue. |
#8 | |
Just here to tinker
![]() Join Date: Jun 2008
And Geezer is right, scoring cylinders is a very common symptom of carb issues.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#9 | |
You could be idling on the power circuit causing the rich smoke you see. |
#10 | |
1981 ![]() |
You buying new stuff or looking for used stuff Mike?
I see stuff for sale down this way and could snag it for you. Did you know there's a guy in Surrey who is an excellent quadrajet rebuilder? |
Holley is selling out old stock Weiand Action+ manifolds right now. http://www.ebay.com/itm/Weiand-8120-...-/360675105342 I just ordered one along with a 600 Summit carb. I'm tired of trying to get my quadrajet (with epoxied idle mixture screws) to idle right.
#13 |
what color is the smoke??
what do the plugs look like?? any pics of the vac leaks?? Qjets are excellent carbs..
JJ 71 SWB 360 Th400 4.56 ![]() |
#14 | |
#15 |
Smoke is whitish-blue and smells of raw fuel, the plugs are black, with deposits on the side electrodes, and the carb is sucking in air from all corners and possible places...
1981 ![]() |
#16 |
Dan, I would prefer to buy new, and I have an account with lordco, which aleady brings a $550 carb down to $480, and a manifold to $150, and I have lots of good experience with Edelbrock, so they are trusted by me, but do keep your eye out, and it costs close the $300 for two people both ways on BC Ferries...
1981 ![]() |
#17 |
On another mission!
1981 ![]() |
