Old 09-06-2014, 11:50 PM   #1
1961Apache
Removing a dash cluster
Is there a secret to removing the speedometer cluster from the dash of my 61 C-20?
I've taken the screws out of the bezel, but it won't budge.
Anything behind the dash?
Thanks in advance
1961Apache is offline   Reply With Quote
Old 09-07-2014, 12:54 AM   #2
slepysal
slepysal's Avatar
Re: Removing a dash cluster
If you have removed the screws you should be able to push it out from behind.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-07-2014, 08:25 AM   #3
earl84
Do you have the speedometer cable removed from the speedometer? Also may have an oil pressure line connected behind the gauge.
earl84 is offline   Reply With Quote
Old 09-07-2014, 08:38 AM   #4
1961Apache
I'll try that. Mine just has the idiot light
Old 09-07-2014, 09:09 AM   #5
1963c-10
1963c-10's Avatar
Sometimes a little push from the back side helps. Some fall right out...some are a little tight.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
