![]() Join Date: Aug 2014
65 C10 tire scrubbing HELP???
Ok guys need some advice I have bought a c10 that had springs heated to lower has P255/70R15 tires. Now problem is my left rear tire is scrubbing the front part of the bed. The right side of the truck has LOTS of clearance. I've removed all wood from the bed due to someone half way installing it all and they also used plywood in it. So all that is removed so I could see if bed was installed incorrectly. I'm not one to half way do anything and this is driving me crazy it only scrubs with the truck is unlevel or going thru a sharp curve like. Any help would be much appreciated. We've had multiple c10s dad says he's had a few 64-66 that the gap was always a little different but never this bad.
![]() Join Date: Jan 2011
Re: 65 C10 tire scrubbing HELP???
Post some pictures up. There was on on here like that a while back and he had a trailing arm badly rusted and folding up.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
you have the springs heated and the pan hard bar is moving the rear closer tto the one side.
My suggestion is get rid of those heated springs, buy you some drop springs and an adjustable pan hard bar. Problem solved for under $150.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
New springs and adjustable panhard bar. The Lower you go the more the trailing arms push the axle up and to the front of the bed. I learned that the block could help some of this dropping the arms down for less push forward.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
will post pics this evening. will just the adjustable bar help any? i plan to bag in the near future just not right now $$$. so i hate to buy springs that will be removed. but mine looks alot like the one above in picture.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
![]() Join Date: Jun 2013
i thought rear gets pushed towards right side when lowered?
Who Me?
I think your right, but an adjustable panhard bar should correct it. I had a similar issue before I got a tire rub.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Ok I haven't been able to get any pictures yet. Sorry. But if y'all believe the pan hard bar will be a good first thing to try then what do y'all recommend cpp adjustable deluxe bar or early classic bar? I'm fairly new at this but would like to do it correct first time around. And would like to do parts that will allow me to lower more in future either static or bagged. Or are there any other brands yall would suggest? I will be doing all install myself so trying to keep it fabrication free. I know springs are needed also but like stated before I'm planing to bag hopefully in future and a cnotch but trying to do small steps at a time. And trying to acquire some white walls also.
i plan on using cpp panhard bar once my rear end is all back together,had similar problem with my tire rubbing left side,turned out to be trailing arm
#10 | |
![]() Quote:
Just reading, it sounds like rear end has been 'twisted'. A quick verification would be to measure the wheelbase on each side and compare. Sam |
#11 | |
I have a adjustable bar I took off and stock 62 mount. If I remember right it is 33.5 eye to eye.
#13 |
any play in the trailing arm mounts? I had one parts truck that the rivets for those mounts were pulled and it just took some new bolts and a lot of swearing.
#14 |
No I've not been able to notice any play in trailing arms. But I'm not also real sure best way to check them for slack?
#15 |
put it up on a lift and look at the TA mounts on the crossmember. Mine were TOTALLY obvious that a problem existed.
#16 |
![]() Join Date: Feb 2014
if its scrubbing the left side its not your track bar unless it was over shortened the track bar moves the differential forward or backward very very little I would measure from a given point on the front of the frame to the differential on each side
#17 |
Reference off the frame rails and measure to the wheel rim on each side. If you see it's tighter on the pass. side then you need an adjustable (shorter) track bar.
