63-66 gmc v6 motor mount stool to frame?
any one have a pic of a v6 motor mount stool thats out of a truck? i am thinking they may be the same as the one for a 292 I6 on the passenger side.
thanks David
Between saying and doing many a pair of shoes are worn out ![]() |
Re: 63-66 gmc v6 motor mount stool to frame?
the first pic in the following link will perhaps show you the difference
http://www.persh.org/pickup/perches.htm ron |
#4 | |
David
#5 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I assume you are looking for the passenger side? If so I will look and see if I may have one.
that would be awesome!
So this is what I did because I couldn't find a perch. I cut 1 inch out of the top mounting holes, of a V-8 perch. then I used some roughly 1" nuts to space the top off the frame rail.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
did you ask for one. I usually have one around
ron |
yep but no one had one so I made my own.
67 may be different I don't know. there are rules for buying and selling on here
ron |
