Old 09-07-2014, 10:48 PM   #1
Gregski
Post Whore
Gregski's Avatar
1974 GMC 15 Hundred - Vacuum Hose Questions
Please brace yourselves for some pesky anal vacuum hose questions, but hey I want to learn and understand what these doohickeys due and where they go?
So first up is this pinky sized hose coming off of the air cleaner housing, where does it connect to? (Obviously I lifted it over the air cleaner to isolate it and show you, it actually goes underneath it)
Gregski is offline   Reply With Quote
Old 09-07-2014, 11:00 PM   #2
geezer#99
geezer#99's Avatar
Re: 1974 GMC 15 Hundred - Vacuum Hose Questions
To the thermac switch on the front of your intake.
Old 09-08-2014, 12:19 AM   #3
Gregski
Post Whore
Gregski's Avatar
This little jobie?
Old 09-08-2014, 01:04 AM   #4
geezer#99
geezer#99's Avatar
I believe so.
If you use google images and search for '74 chevy vacuum diagram' you might find where all the hoses go.
https://www.google.ca/search?q=1974+...h=709#imgdii=_
Old 09-08-2014, 11:32 AM   #5
hatzie
Moderator
hatzie's Avatar
The Vacuum diagrams are in the GM service manuals and maybe on the radiator support label. At least some of them are...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-10-2014, 10:08 AM   #6
Gregski
Post Whore
Gregski's Avatar
I believe so [...]
Negative Ghostrider, LOL, jk
but you guys have been helpful, piecing together all the information provided it appears the EGR valve connects to the top of the two port thermal vacuum switch mounted in the thermostat housing while the bottom port of the thermal vacuum connects to a supply port in the carburetor.
Where my doohickey goes remains a mystery?
Here's a shot of what lurks beneath the air cleaner housing.
Old 09-10-2014, 10:56 AM   #7
geezer#99
geezer#99's Avatar
I've been wrong before!! LOL!!
So I looked on my 84 and your doohickey plugs into a manifold port on my carb.
But I bet your choke would work a lot better if you hook up the choke pulloff pot!!
Old 09-10-2014, 11:02 AM   #8
Dead Parrot
Your air cleaner THERMAC gizmo connects to the dusty looking capped pipe coming out the side of the carb. The small clean looking vacuum pot end connects to the small clean pipe on the carb. There may be a missing piece as the picture I have of a 74 carb shows that pot hose connector rotated about 90 degrees so it mostly points at the carb connection. Or a PO may have used the wrong pot during a repair.
The THERMAC flapper pot connects to a temp sensor in the air cleaner, then from the other side of the temp sensor to the carb.
Dead Parrot is offline   Reply With Quote
Old 10-09-2014, 05:18 PM   #9
Chaplain
Chaplain's Avatar
Chaplain is offline   Reply With Quote
