Old 09-08-2014, 12:14 AM   #1
Ugly71C20
Running C10 Lower Control Arms With C20 Spindles
So I screwed up and misread that I could swap ball joints and run c10 lower control arms on a c20. Got the c10 joints pressed out and they c20s are nowhere close to fitting. Not sure how I didnt noticed that before I pressed them out
Is there a ball joint that has the c10 cup size and c20 shaft size? Or a sleeve I can run to make a c10 joint work? Or am I SOL and need to look for some c20 arms?
Ugly71C20 is offline   Reply With Quote
Old 09-08-2014, 10:02 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Running C10 Lower Control Arms With C20 Spindles
I am not aware of any replacement ball joint that will work.... a set of C20 arms are in your future.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-08-2014, 11:00 AM   #3
Ugly71C20
I was going to call you on my lunch break today. What do you think about cutting the smaller cups off and welding a c20 cup on? The arms are cpp's and it looks like it could be done with a little jigging
Old 09-08-2014, 11:18 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
It could be done. Not something that we would do here, but we could definitely sell you a couple of the ball joint cups we use if you are wanting to tackle it yourself.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-08-2014, 11:22 AM   #5
Ugly71C20
Thanks for your help. I'll give you a call later today and either order some cups or some new arms
