Old 09-08-2014, 12:52 AM   #1
crazychevyc10
Whats a good affordable exhaust/muffler?
Hey guys...just trying to see what you guys have out there? I just got my 68' c10 and it currently has a straight pipe to 2 glasspacks on right now. It sounds really good and loud but I feel like it doesn't have good high end power. I was thinking of taking out the glasspacks and running straight into the mufflers. What do you guys think?
I'm looking for a loud and yet affordable mufflers to add to it. Also if you have pics of your exhaust that would be awsome! I currently have pipes running to both sides of the truck running out before the rear wheels.
Thanks!
crazychevyc10 is offline   Reply With Quote
Old 09-08-2014, 01:49 AM   #2
crazychevyc10
Re: Whats a good affordable exhaust/muffler?
Thanks!
This would be for a 350 engine
Old 09-08-2014, 08:50 AM   #3
DreamRyder1963
DreamRyder1963's Avatar
Power wise a decent glasspack is as close to race exhaust has you can legally have on the street. The only reason it would lose power is if its stopped up. Do you have 2 glasspack mufflers on one pipe or do you have dual pipes?
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 09-08-2014, 10:14 AM   #4
crazychevyc10
i have dual pipes setup right now. i was thinkingnof taking them out and adding flowmaster 40 series mufflers on each side. . im hopong to get better high end power with it
Old 09-08-2014, 10:40 AM   #5
Lee H
Lee H's Avatar
You are highly unlikely to get any more high end power by switching out the mufflers. You will however change the sound big time.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-08-2014, 10:41 AM   #6
DreamRyder1963
I would be doubtful that a turbo style like flowmasters will make anymore streetable power. Don't get me wrong, the are good mufflers and sound good on a sbc. Just don't expect a load of power gain.
Old 09-08-2014, 10:45 AM   #7
crazychevyc10
do you think its better to keep my striaght pipe with the glass pack on then to get the most optimal power?
Old 09-08-2014, 10:58 AM   #8
DreamRyder1963
Honestly you probably would not notice a power difference between the two setups. Your choice in a street exhaust system is more about the sound then power. I have thrush glasspacks on my truck because I wanted the old school hot rod hellraiser sound. If I build another truck it will have raptor turbo mufflers on it. They have an aggressive sound at idle and acceleration but quiets down at cruise.
Old 09-08-2014, 12:55 PM   #9
leftybass209
leftybass209's Avatar
Don't take this the wrong way, if you are trying to make more power, the muffler is the last place you should be looking, especially if you already have a straight through glasspack design. There are loads of engine specific options you need/can be looking at to create more top end power. We need a lot more specifics as to your engine, internals, intended RPM range, ie: 5k limit, 6k limit. To start, these trucks never had top end power as the engines were intended for low end torque, so you'd be overhauling your engine to assemble components that all create power within your specific RPM range. Engine building is a lot more than slapping on pretty parts that advertise horsepower claims in their ads.
leftybass209 is offline   Reply With Quote
Old 09-08-2014, 08:37 PM   #10
Fitz
Thanks!
On a good day switching from stock mufflers to a straight through design is worth 10 horsepower. On a bad day you lose 20 horsepower by setting your timing incorrectly or having fouled plugs. There are much better places to chase HP than mufflers.
Fitz is offline   Reply With Quote
Old 09-08-2014, 08:46 PM   #11
Grumpy old man
Grumpy old man's Avatar
UMMM Fellers ? He is in CA I would venture to bet he has 2 catalytic converters and NOT GLASS PACKS going into his mufflers ! BIG DIFFERENCE ! And if there clogged from reaming the truck trying to find high end power from a probable smoking engine and those converters trying to burn the oil well...You get the picture .
Grumpy old man is offline   Reply With Quote
Old 09-08-2014, 09:36 PM   #12
Fitz
Noticed that too, Grumpy. He's gotta move off of the left coast if he wants mo powah. New mufflers just aren't gonna cut it!
Old 09-08-2014, 09:40 PM   #13
Lee H
Lee H's Avatar
1975 was the first year cats appeared on trucks under 6k GVW, and then only one.
Old 09-08-2014, 09:52 PM   #14
Grumpy old man
Have you ever seen glass packs in front of mufflers ?
Old 09-08-2014, 10:00 PM   #15
Lee H
Lee H's Avatar
I'll have to retread the post, did not think that's what he has. I have seen a few folks try run dual cats but the California air resources board rejects those for smog compliance. Only y pipe, into one cat, then to muffler or mufflers (what ever was factory) would pass visual inspection. Only in the last 10-12 years have dual cats, on trucks, come factory.
Old 09-09-2014, 09:29 AM   #16
smoked68
smoked68's Avatar
40 flows with three inch pipes from headers out back.. deep sound.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 09-09-2014, 09:42 AM   #17
Fitz
Only on clown cars.
Old 09-09-2014, 11:20 PM   #18
min
min's Avatar
I have the summit race mufflers and they are a knock off of the flowmaster 40 series and are only $30. can't comment on there performance because truck is a long way from done and I have a 170hp 305, but they sound great.
min is offline   Reply With Quote
