Old 09-08-2014, 11:33 AM   #1
Grumpy old man
Grumpy old man's Avatar
Low cost chain covers - Super easy install ! Less than 5 minutes
I have a new LOW COST design for step bed chain covers made from Automotive UV treated VINYL stitched with UV treated NYMO thread the best thread you can buy ! The chain cover shown is 18 inches long( measure your chains for the length you need ) and has a cable tie sewn into each end to keep the covers from sliding down off chain ends . Since these are flexible there is NO need to remove your chains to install ! Simply slide 1 end over the chain hook end and slide it down to the bed connector -tighten cable tie snugly and trim cable tie with diagonal cutters repeat the same thing on hook side and your done ! These come with a drain hole so there is NO NEED to empty rain or wash water from them !
$25.00 a set of 2 SHIPPED ! No more scratched paint -No more rattling chains -- multiple colors available ! PayPal ---can be stitched with team colors
http://http://http://http://http://
Grumpy old man is offline   Reply With Quote
