Old 09-08-2014, 11:46 AM   #1
ddr11
ddr11's Avatar
Brake light wiring
I've just about completed my 87 R10 Step Side. I am wanting to add a 3rd brake light, I've got new LED flush mounted tail lights that also are the signal lights. My concern is if I pick up the brake light wire at the rear of the truck I think the 3rd brake light will flash as well instead of just for braking. My question is where can I pick up a circuit for just a brake light... at the brake switch? fuse block?
ddr11 is offline   Reply With Quote
Old 09-09-2014, 06:36 AM   #2
DBLSPRT68
DBLSPRT68's Avatar
Re: Brake light wiring
Tap off the brake light switch at the pedal. I did this on my old C20. Just run the wire from the pedal switch down to the floor, under the carpet at drivers door, and up the left side of the cab. If you truck has the bed light/cab light installed, follow that wire. David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 09-09-2014, 09:02 AM   #3
JJLT1
JJLT1's Avatar
x2 brake light switch
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 09-09-2014, 02:43 PM   #4
ddr11
ddr11's Avatar
Thanks guys I found a White wire at the brake switch that will work. DBLSport I see you too are in SC
