Old 09-08-2014, 02:52 PM   #1
1963c-10
1963c-10's Avatar
60-63 trucks with metal framed door glass question
Just about at the point to start disassembly on the doors for paint. Have located all new gaskets and seals for the doors. Question is the division bar....I only see the felt with the two sided tape for the metal framed glass. Does anyone have a source for the division bar felts that press in as opposed to the stick on version?
This is for my 63 stepside.
1st pic is what I have....2nd pic is the style I'm looking for. I've checked all the usual vendors and can't seem to find them. I do see a 55-63 (2nd series).....that may work as I think a lot of them had the metal frames.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-08-2014, 03:03 PM   #2
davbowen
davbowen's Avatar
Re: 60-63 trucks with metal framed door glass question
I used the felt type on my 63 w/ metal frames. worked great. sprayed on contact cement on back side of felt placed it in had a little time to maneuver it around before it setup.
davbowen is offline   Reply With Quote
Old 09-08-2014, 03:11 PM   #3
1963c-10
1963c-10's Avatar
Thanks....that may be the way to go then. I'm wondering if the framed windows received this style of liner on the division bars due to the added thickness of the frames and the standard glass got the push in style of liner.
I checked through my literature and couldn't find any specific reference to them.
Old 09-08-2014, 03:23 PM   #4
1963c-10
1963c-10's Avatar
Also looking for the inner door panel seal. Starts about mid way up the door and seals the inner panel to the door. (visible on the inner door in this pic)
Old 09-08-2014, 04:33 PM   #5
1963c-10
1963c-10's Avatar
This is the bar sold by Ecklers that shows 55-63
link: http://www.ecklerstrucks.com/chevy-t...Product_Viewed
Old 09-08-2014, 06:51 PM   #6
davbowen
davbowen's Avatar
lmc truck sells the inner door panel seal your looking for.
Old 09-08-2014, 08:26 PM   #7
FF SIX ONE
FF SIX ONE's Avatar
Try truckandcarshop.com or classicparts.com. My truck has the same window set up and i also did the two sided tape type.
FF SIX ONE is offline   Reply With Quote
Old 09-09-2014, 07:57 AM   #8
1963c-10
1963c-10's Avatar
I have 61 (framed glass) & 62/63 doors at home. On my doors, the framed glass has the felt/mohair style liner and the standard glads doors has the thicker liner. So I think its correct.
Old 09-10-2014, 12:44 AM   #9
Captainfab
60-66 Nut
The window channel felt shown in the 2nd pic in your 1st post, I believe is for the upper and rear channel, not the division bar. In the past the division bar replacement was a rigid piece with new felting that was installed with rivets. Member Alans Classic did a writeup here on rebuilding the wingwindow, that should shed some light on this.
Old 09-10-2014, 08:45 AM   #10
1963c-10
1963c-10's Avatar
The 2nd item shown is what all the catalog companies are selling for the standard glass division bars. The pics above are from classic parts. My metal framed glass division bars (1961) still have the original felting which is the thin style. My 63 doors are standard glass and have the thicker style.
I'm familiar with the upper and back door felting and agreed it looks the same. I just know that everyone only offers the stick and peel style for metal lined windows. I'll try and get some pics of the different year division bar felts tonight that I have for reference....at least in my applications and what I have.
The glass frames are cleaning up nicely.
Old 09-10-2014, 08:51 AM   #11
1963c-10
1963c-10's Avatar
03-406 division bar relining felt 55-63 for metal frames
03-407 division bar relining channel for trucks w/o metal frame 60-63
03-455 deluxe division bar for truck w/o frame 60-63
03-313 door glass channel 60-63 (top & back of glass)
Old 09-10-2014, 09:03 AM   #12
pimpston65
pimpston65's Avatar
here's what i have off a 65 w/o frame division bar. got my inserts from precsion brand,snug no glue required. put my SS trim back on and trim the excess... ps i see ur missing one of the two gas tank sending unit wire clips, hehe...
pimpston65 is offline   Reply With Quote
Old 09-10-2014, 09:05 AM   #13
1963c-10
1963c-10's Avatar
Originally Posted by pimpston65 View Post
just had to trip the excess.
But you have standard glass in the 64-66's....I don't think the metal frames were optioned for those years. Was trying to find a "deluxe" style for the metal frames....not just the paste and stick felts.
Old 09-10-2014, 09:24 AM   #14
pimpston65
pimpston65's Avatar
was GMC's that way? maybe you can cross ref. those type...
Old 09-10-2014, 11:18 AM   #15
1963c-10
1963c-10's Avatar
Hmm....worth a shot. I honestly don't know, but I don't see anything listed specifically through the 15-20 usual venders I use.
Does anyone know if the GMC had the framed glass option?
