Old 09-08-2014, 06:11 PM   #1
Wrcampbell
Pertronix Ignitor 1
So Whats everyones thoughts on this upgrade. I want to replace my points but dont want that huge HEI unit, want the stock look so i was looking at this system. Just looking for advice and any comments from any of you have used this system. Thanks
Wrcampbell is offline   Reply With Quote
Old 09-08-2014, 06:12 PM   #2
Wrcampbell
Re: Pertronix Ignitor 1
Oh btw 1970 C-10 307 manual stock stock stock lol
Old 09-08-2014, 06:34 PM   #3
Koffer
Haven't put one in any of my Chevys but I did put one in my 65 VW bug about 10 years ago and haven't had to mess with it since then . I've been very pleased with the unit
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model )
Koffer is offline   Reply With Quote
Old 09-08-2014, 07:02 PM   #4
FLDBRED
Most reviews will be in favor, a couple will not. I recently put one in my 71 Shortbed, very easy to install and worth it in my opinion. You might want to look at the Ignitor III however.
FLDBRED is offline   Reply With Quote
Old 09-08-2014, 08:23 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
I put the Ignitor II [and Flamethrower II Coil] on the L6 292 in my '68 C/10 Stepside. Works real good. Simple install. About 5 years running with no problems.
A couple of notes: I heard the Ignitor (I) will burn out if the key is left on w/o the engine running. The later Ignitor II shuts itself off. Don't know if they corrected this gripe in the first model.
Also, since it's a multi-spark device, the Ignitor III has signal issues with running tachometers. Their tech reps themselves recommended a couple of Pertronix III owners to downgrade to the Ignitor II to fix their tach problems. The Ignitor III is only available for V8s.
The Pertronix system is also designed to run with the corresponding proprietary coil.
One other thing -- you must run a seperate 10 or 12 gauge wire from Ignition Unfused to the positive (+) lead on the distributor module -- using the stock Yellow 20 to the coil positive terminal will result in performance loss as the resistor wire heats up and drops the voltage feed from 12 VDC to 7-9 VDC.
Old 09-08-2014, 08:26 PM   #6
Wrcampbell
Cool thanks! Sounds like im gonna go with Ignitor II. Sounds like less problems for a daily driver truck. Thanks again
Old 09-08-2014, 09:41 PM   #7
70cst
70cst's Avatar
I have used Pertronix on my 402BB for about 10 yes and as of today ... no issues
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-08-2014, 11:26 PM   #8
9teen69
9teen69's Avatar
I went with an HEI ready run and flamethrower. Looks stock at first glance. Running for 2 years now.
http://www.ebay.com/itm/SBC-BBC-CHEV...10b00e&vxp=mtr
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 09-09-2014, 09:08 AM   #9
brown7373
brown7373's Avatar
I have run both Ignitor I and II starting in the mid 90s with zero problems on 5 different cars, some running tens of thousands of miles. I have never had to run a 12 volt wire or upgrade the coil. You will NOT gain any horsepower over a properly set up stock points distributor. I think Pertronix says "some" applications need a 12 volt. The stock spark is more than adequate to ignite the mixture of any stock engine. What you WILL gain is a distributor that will perform like a stock points unit distributor with brand new, properly adjusted points and condenser, all the time with no adjustments.
The only car that actually gained power was a 69 Corvette with 350 horse 350, 11:1 compression and a 6000 redline. The cheap points available today would float above 5000-5500 rpms, whereas the Pertronix would let the engine rev right past 6000 rpms. Unless you have a highly modified engine, or high compression or high redline, this doesn't apply.
I upgrade to Pertronix on every old car I buy.
brown7373 is offline   Reply With Quote
Old 09-09-2014, 10:10 AM   #10
Matt Cramer
Used an Ignitor 1 in my '66 Dodge Dart with the stock coil. Had zero complaints about it - it was like adjustment-free points, not a performance upgrade really, but it saved a lot of hassles and was as easy to install as changing points.
Only ditched it because I wanted to swap to an electronically controlled distributor for a turbo build.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 09-09-2014, 10:22 AM   #11
Coley
Coley's Avatar
I've done the Pertronix (1) upgrade to 3-4 trucks now.....zero complaints on my end.
I didn't run any extra 12 volt wires or anything along those lines..... just hook it up as per the instructions....they have all run and started great (and quickly) without issue.
Go for it....get rid of those points!
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-09-2014, 10:48 AM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
No. Still a "problem." These are extremely popular in the first gen mustangs, I have one in my 65. Quite a few people have "burned up" theirs by leaving the key on. I've had mine in for a couple years. Happy with it so far.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-09-2014, 12:13 PM   #13
brown7373
brown7373's Avatar
I never viewed the issue with burn out if left in the run position an issue. That does not pertain to having the key in the accessory position, only the run position. That is if you turn the key to run, but not to the next position to engage the starter. There is no reason to keep the key in that position without the engine running.
Old 09-09-2014, 03:15 PM   #14
brown7373
brown7373's Avatar
Something else to stress with the Pertronix install, is to make sure you read the instructions and pay attention to the tolerances. Most applications you should remove the distributor so you can make sure the amount of slop in the lower gear is within spec. If it is not, it is easy to shim with the included hardened washers. If the gap is too large, when you accelerate, the shaft will lift up and the gap that triggers the spark will be too large and you will get misfire. Some guys just slap it in and don't pay attention to the detail, then complain that it doesn't work. Some distributors are within specs. some are not, but you won't know unless you remove it and measure the gear and install washers as required.
Old 09-09-2014, 03:42 PM   #15
'68OrangeSunshine
The '67 model year does not have the ACC position.
Old 09-09-2014, 04:48 PM   #16
steelhorse
steelhorse's Avatar
I recommend an upgrade from points to electronic to all my customers with old cars. I usually use a Petronics kit and have never had a problem with any of them. Every car or truck I have put one on has run better and made better power. Well worth the money.
steelhorse is offline   Reply With Quote
Old 09-09-2014, 07:10 PM   #17
SCHRUMGMC
SCHRUMGMC's Avatar
I want to use the Type I, so I can get rid of the points on my I6
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
