09-08-2014, 06:23 PM | #1 |
Diesel Questions
Okay so I'm looking to do a Cummins swap in the near future, but I have a few questions that need answered first. First question, is it easier to swap a Cummins into a previous diesel Chevy compared to a gasser? Second question I'm finding it kind of hard to find K20's and K30's around me. Is there any real difference between the K20's and CUCV's? Or the K30's vs the K20's? And last what does everyone think would be better to do the swap into a regular cab long bed or a crew cab long bed? I'm kinda split right now on either option so I need convincing either way. Any help would be appriciated guys.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
09-08-2014, 10:03 PM | #2 |
Re: Diesel Questions
The advantage of installing a Cummins in a previously equipped truck is it'll already have hydroboost brakes and 4 core radiator. They may also have gears more appropriate for a low revving high torque engine.
As far as regular vs crewcab, there are a lot more conversions using crewcabs out there. Regular cab conversion would be more unique. Very unique would be regular cab short box.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
09-08-2014, 10:15 PM | #3 |
The CUCVs are just a K30 with no frills and a special wiring harness for the 24v starting system, dual alternators, blackout lights, TH400 trans, 208 or 205 transfer case depending upon model, 4.56 gears and a Detroit Locker in the rear. M1031s had a TruTrac locking diff in the front an all had the NP205.
The CUCV Blazers are a no frills Blazer with the same specs except 1/2 axles, 3.08 gears, and GovLoc limited slip rear and rated at 3/4 ton suspension
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
09-08-2014, 11:28 PM | #4 |
So heavy duty wise either or wont matter? And now i guess i just play the hunting game.
09-08-2014, 11:37 PM | #5 | |
It depends on what you want to do with the truck. If you're going to be doing heavy duty off roading or pulling with the engine pumped up to insane power levels, it'll matter. But for everyday highway driving, even 1/2 ton is strong enough.
09-08-2014, 11:45 PM | #6 |
Power, and itll be used for work too. It will eventually be p pumped and built.
09-08-2014, 11:56 PM | #7 |
I would not do a Cummins in a K20 front axle wise.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
09-08-2014, 11:57 PM | #8 |
Why not?
09-09-2014, 12:11 AM | #9 |
1000 lbs sitting on a half ton axle housing?
All that torque through a half ton ring and pinion and axle? Dodge and Ford never did.
09-09-2014, 12:13 AM | #10 |
Okay I was thinking the K20's had Dana 60's
09-09-2014, 12:43 AM | #11 |
Just here to tinker
Many half tons came with the 800 LB Olds 350 and 750 LB 6.2 diesel. Those 1/2 ton axles should have no problem supporting an extra 100-125 LBS per side.
I will be putting a 5.9 Cummins in my 2wd half ton short box and the only thing I will be beefing up will be the steering bracket so the frame doesn't crack under the weight. All factory 1/2 ton diesel trucks came with 3/4 ton springs and heavy duty brakes (2wd anyways).
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
09-09-2014, 12:49 AM | #12 |
I want heavy axles and frame, something that i can actually use the Cummins with. So i should be lookimg for a K30 not K20?
09-09-2014, 03:49 AM | #13 |
A k20 has a dana 44 or 10 bolt front axle depending the year.Only thing factory with a dana 60 was a k30.Now you can swap in a dana 60 in a k20 or even k10 if you want it.Have you looked around http://67-72chevytrucks.com/vboard/f...play.php?f=240
09-09-2014, 08:48 AM | #14 |
Yeah Ive started to look around but I was under the impression that K20's had Dana 60's up front not 44's. That being said would the crew cabs have 60's or 44's?
09-09-2014, 09:19 AM | #15 |
k10 will have 10 bolt k20 44 or 10 bolt maybe 12?? k30 d60 nothing else. one down side to a dana 60 and 14 bolt lowest gear combo is 3.54 so you will need a real good over drive or big tires to go down the highway at speed without the motor tached out
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
09-09-2014, 09:24 AM | #16 |
I'm fine with that a 99 Dodge Cummins is my daily driver so I'm used to that. Now I need to look for a truck, but is a CCLB SRW considered a K20 or K30?
09-09-2014, 09:26 AM | #17 |
6.5s weigh 650 dry. B6 is 1100 lbs dry.
09-09-2014, 09:27 AM | #18 |
You mean 6bt's?
09-09-2014, 09:34 AM | #19 |
Yea. Its early here.
09-09-2014, 09:37 AM | #20 |
Haha okay just wanted to make sure i wasnt missing anything, and its early for me too.
09-09-2014, 09:37 AM | #21 |
CCLB are all 1 ton's
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
09-09-2014, 09:41 AM | #22 |
So they would definitely have Dana 60 fronts?
09-09-2014, 10:42 AM | #23 |
Most 1 ton trucks are geared too low for a Cummins unless you plan to use monster tires or have very limited top end speed.
09-09-2014, 10:56 AM | #24 |
Gearing is not my question here, i am constantly around 4 Cummins trucks so I know how they drive i am completely satisfied with that. I just want to make sure I get good axles.
09-09-2014, 01:36 PM | #25 |
You need to define good. Dana 60 axels with 4.56 gearing might be good for mudding but not for going down the highway at 60 mph or getting good fuel economy.
